santa brought me a 2.4L, finally...
Old 03-04-2008 | 03:43 PM
  #51
IonNinja's Avatar
wow 7K and a broken balance shaft? would be the first I've heard of that, must have been a freak occurance...that sucks.
IIRC Level Zero doesn't advertise this kit because they can't gaurantee long time reliability right? It would suck to spend all that money on the motor just to rebuild it later.
Old 03-05-2008 | 05:42 AM
  #52
bigworm's Avatar
clayton gave me the "talk" already. =]
It could have been a freak accident, but damn it, im not letting it happen again. At this point in time, it seems more reliable to simplify the number of moving parts. Theres a few cavs that have gone 40,000 miles with the bsd, worst-case, another rebuilt after 50k? i'm okay with that... and you can bet i'll be doing another delete then too..
btw, i only had 15k miles on the car and the single ZZP motor mount i had shaked the car more than other ecotec's with full solid mounts... the chance that the balance shaft's bearings where jacked from the factory are very high. Looking at the aftermath, the bearing (now sitting in the oil pan) went first.
tick tick rattle rattle
Old 03-05-2008 | 03:14 PM
  #53
bigworm's Avatar
finished porting the exhaust side. heres some crappy pics... they really dont do it justice.
After only 15k miles, stock ports:
middle of shapping the port with 80grit:
this is a horrible picture, bad lighting or something... in person this shines very nicely.
i dont think i have the patience to do the intake as the size of the runner is very long. I did do these with the valves in place because i bought two valve spring tools and niether where small enough to remove the valves... but i didnt go deep enough to touch the valves, just gasket matched header and ports and feathered that middle section alot.
oh well, im happy with my half-assed attempt.
Old 03-05-2008 | 03:56 PM
  #54
OneSlowGto's Avatar
You impatient bastard
Old 03-05-2008 | 10:44 PM
  #55
bigworm's Avatar
actually looking at the intake port i dont see much gain possible.. other then port matching it the design is very nice.
Old 03-09-2008 | 01:57 AM
  #56
bigworm's Avatar
engine is in. ran out of daylight and will have to wait til tomorrow to finish up wiring and hoses...
Old 03-09-2008 | 07:09 AM
  #57
Beck's Avatar
woot
Old 03-11-2008 | 12:30 PM
  #58
pjk91's Avatar
running yet?
Old 03-11-2008 | 07:00 PM
  #59
bigworm's Avatar
nope. Having problems removing the security light so the car went to a dealership this morning.
it maybe a while because they may need to order a new ecu.
Old 03-11-2008 | 07:02 PM
  #60
OneSlowGto's Avatar
Should just leave it there and get a goat.
Old 03-12-2008 | 03:41 PM
  #61
bigworm's Avatar
heh, gunna hold out a while longer.
i've spent and bleed too much on this car... no going back.
Old 03-12-2008 | 03:45 PM
  #62
Beck's Avatar
did you get the beast running or what? :P
Old 03-12-2008 | 05:14 PM
  #63
bigworm's Avatar
the dealer replaced the ecu and it now cranks over but doesnt start.
most likely at this point a cable going to the wrong sensor and/or case relearn.
he'll call me later today with another update. I _might_ have a running car by 5pm today!
Old 03-12-2008 | 07:02 PM
  #64
Beck's Avatar
its 5pm, gimmie an update sucka!
Old 03-12-2008 | 07:06 PM
  #65
madmark's Avatar
theft light lol? what the **** did you do to the theft system
Old 03-12-2008 | 08:15 PM
  #66
OneSlowGto's Avatar
I see a gto in the near future.....
Old 03-13-2008 | 12:23 AM
  #67
bigworm's Avatar
no car yet =[
the car sat for a year without power.
your a mean man =[
Old 03-13-2008 | 04:14 AM
  #68
OneSlowGto's Avatar
Nothing wrong with a gto
Old 03-14-2008 | 01:36 AM
  #69
bigworm's Avatar
I've decided to rename my cobalt Murphy.
About 3 this afternoon I picked her up from the dealer, brand-new ecu and she started right up. I was SO EXCITED until i had a horrible time getting it home.
Not only did they not refill it with water, they didnt put the hose clamps back on the hoses, or put the belt back on the alt... Why do i have such horrible luck with dealers?
long story-short, i overheated on the freeway coming home, i ran out of battery 10mins out of the dealership... and then when i got her home and replaced everything, changed oil and got her running perfect... the ****** starter died.
Old 03-14-2008 | 02:33 AM
  #70
SlowBalt_06's Avatar
god damn thrum maybe its just not ment to be
Old 03-14-2008 | 05:53 AM
  #71
OneSlowGto's Avatar
God damn devil Cobalt. There is a silver one on a mazda lot that you might have better luck fixing up
Old 03-14-2008 | 06:12 AM
  #72
bigworm's Avatar
Naw, its disappointing, but thats how these things go.. the car sat for a year... its to be expected.
heh, "get that blue 06 ls2 gto!" and now your like.. "buy my sloppy seconds!"...
Old 03-21-2008 | 09:21 AM
  #73
bigworm's Avatar
I havent posted updates in a while because its just more bad ****.
I put the new starter in, started it up and got tons of blue smoke (correction: white smoke) out the back... turns out from overheating on the freeway that i blew the headgasket and was filling #1 up with a ****-load of water. She ran VERY well for having a blown head gasket, idle was smooth, unnoticeable vibes from the BSD with all stock mounts. I'm sure this will change when i put the ZZP mount back in.
I've already taken the head to get milled and ordered a new head gasket which will be here mid-next week from cosmetic. and the new zzp downpipe+gaskets has come in so i can get rid of the existing exhaust leak.
Lets hope this is the last of the issues...
Old 03-21-2008 | 10:47 AM
  #74
IonNinja's Avatar
wow that is terrible
i was kinda surprised when you didn't have any news of a blown headgasket or motor from the previous post
Old 03-21-2008 | 02:34 PM
  #75
OneSlowGto's Avatar
"Murphy"!!!!
Quick Reply: santa brought me a 2.4L, finally...
