sc build, what should I aim to get next
Old 05-24-2008 | 12:49 AM
Dragonsfire12345's Avatar
So I got the intake manifold, and the supercharger will be here on wednesday. I also have a cobra heat exchanger, which I'm thinking of selling and getting the CX Racing heat exchanger. So yeah question is what should I buy next? Or where can I get parts from, just need help being pointed in the right direction.
Old 05-24-2008 | 12:51 AM
KillerBee's Avatar
might be a dumb question do you have the injectors?
Old 05-24-2008 | 12:55 AM
nope, I guess I could get those next. Which ones should I get? sc comes witha 2.7in pulley
Old 05-24-2008 | 12:58 AM
hungryhip-ccp's Avatar
well then your gonna need 60's
Old 05-24-2008 | 01:07 AM
InfinityzeN's Avatar
2.7" is way to small a pulley to be running unless you have built your 2.4L up and put lower compression pistons into it.
Old 05-24-2008 | 01:09 AM
ColeJJones's Avatar
Bannned
^ yep. you will be runnin the 2.9 at the lowest.
Old 05-24-2008 | 01:37 AM
so then a 2.9 and 60lbs
Old 05-24-2008 | 01:45 AM
KillerBee's Avatar
yup with all supporting cooling mods
Old 05-24-2008 | 10:54 AM
Jimmys2007CobaltSS/C's Avatar
i got my s/c kit on the way
Old 05-24-2008 | 11:16 AM
06blackg85ss's Avatar
I still have some more brackets and **** laying around if you need... water pump bracket, stock HE, coolant res, some hoses etc etc etc ...... Since you already have my pretty blue/green intake mani, might as well grab the rest lol
Old 05-24-2008 | 10:03 PM
sent ya a pm
Old 05-26-2008 | 01:26 AM
another question, should I keep my 2.5in exhaust(borla XR1 muffler, and vibrant header w/ hi flo cat) or upgrade when the time comes to a 3in exhaust?
Old 05-26-2008 | 04:20 AM
Shaun927's Avatar
2.5" is fine for an sc
Old 05-26-2008 | 10:52 AM
mike25's Avatar
3 in is for a more serious setup...depends on where your going with your car
Old 05-26-2008 | 12:39 PM
Smitty1017's Avatar
I would suggest finding a stock ss/sc pully to start off with. You are also going to need all gaskets and the ss/sc throttle body and alot of other ****.
check out becks 2.4l supercharged how-to for info.
05-28-2022 03:47 AM
ineedacobaltss
11-07-2015 02:25 PM
hacadacalopolis
10-28-2015 06:09 PM
patooyee
10-15-2015 05:11 PM
09-26-2015 06:44 PM
Quick Reply: sc build, what should I aim to get next
