sc question??
Old 12-14-2015 | 12:28 AM
sS07NA's Avatar
sc question??
I have multiple questions on supercharging the 2.4 2007 model
:can I run stage 2 on stock internals
:can my fuel rail suport 60lb injectors
:What's thr most/safest lb of boost I can run
Old 12-14-2015 | 12:55 AM
LsCobalt07's Avatar
Yes, you should be fine running a stage 2 pulley. The fuel rail fits 60lb injectors. I'm not sure what the safest amount of boost would be but I'm guessing 12 to 14 psi.
Old 12-14-2015 | 01:34 AM
chevygirl2006's Avatar
Yes.
Yes.
The amount of psi depends on the pulley size.
Old 12-14-2015 | 03:53 AM
sS07NA's Avatar
Yes.
Yes.
Bought the pulley from Jeff r. all I know is its stage 2 but has 73.0 On it
Old 12-14-2015 | 03:58 AM
sS07NA's Avatar
Also would I be able to drive it at all unturned? ?
Old 12-14-2015 | 10:14 AM
Haven07's Avatar
You would need to be tuned
Old 12-14-2015 | 10:45 AM
sS07NA's Avatar
Also how did u get the injectors to fit being the lsj connectors goes up rather then at a angle like the ev6?
Old 12-14-2015 | 01:38 PM
Staged07SS's Avatar
Administrator
Administrator
Yes.
Yes.
and airflow of the engine...
A free flowing exhaust, and or cylinder head will lower psi (which is a good thing).
Old 12-14-2015 | 04:07 PM
sS07NA's Avatar
I have a full exhaust custom welded
Old 12-14-2015 | 05:37 PM
Your stock injectors are ev6. You have 3 choices. Buy ev6 injectors and plug and plug, or buy ev1 injectors and buy the adapters zzp sells. Or cut and splice.
Old 12-15-2015 | 07:15 AM
Staged07SS's Avatar
Administrator
Administrator
Good.
Old 12-17-2015 | 02:46 PM
sS07NA's Avatar
For the a/f gauge would i need a a/f controller? Or just the gauge?
Old 12-25-2015 | 05:37 PM
Get aem
Old 12-27-2015 | 02:52 PM
ItalianJoe1's Avatar
73mm pulley is just under 2.9", a bit smaller than stage 2 but if the car is tuned properly it should be fine.
Old 12-27-2015 | 07:21 PM
sS07NA's Avatar
Koo thx couldn't find anything on that
.. also wonder if my numbers r off but tuner got 270whp with 260lb with a slipping clutch and 90% of the tune done
Old 12-27-2015 | 07:22 PM
sS07NA's Avatar
Old 12-27-2015 | 08:38 PM
Is that a vitrual dyno? Or are you actually being dyno tuned?
Old 12-27-2015 | 09:43 PM
sS07NA's Avatar
Dyno tuned
sS07NA's Avatar
That's @9lb
Old 12-27-2015 | 11:13 PM
Jesse's Avatar
Pretty good numbers. I forget, do you have a ported head?
Old 12-28-2015 | 10:55 AM
Auto or manual? Now I'm curious to see what mine puts down with a 2.8 pulley 80s and e85 lol
Old 12-28-2015 | 02:14 PM
Jesse's Avatar
Same here on my 2.2
Old 12-28-2015 | 05:49 PM
joeworkstoohard's Avatar
lol, wanted to put a blower on my 2.4 since i bought it... new, in 2006
Old 12-29-2015 | 04:38 AM
sS07NA's Avatar
No stock motor.. manuel tans
Old 01-08-2016 | 04:09 PM
sS07NA's Avatar
Would it be considered a 2.9 or a 2.8?
Quick Reply: sc question??
