SC vs Bolt Ons
SC vs Bolt Ons
So for around the same price I can either get a used complete lsj supercharger kit or get full bolt ons. Which would be better? The sc kit would be really restricted with the stock le5 parts would it not?
Don't know how relevant this is, I have an LSJ and run a 2.8 pulley. lately I have been driving with my AERORORCE Interceptor set on boost reading. I notice most of the boost is typically under 8 lbs.
I was thinking to myself this is why it is a popular upgrade to add the SC to the 2.4
I think as long as you don't go too wild on the boost your 2.4 will hold up very well and the upgrade will definitely be worthwhile.
you might make 170whp with full bolt ons. you'll make 225+whp with the supercharger kit alone. Not too hard to figure out where you should spend the money first.
when I install my supercharger, I'll do a CAI and mid length header at the same time, just so I dont have to keep having it tuned.
I really wish I skipped the whole bolt-ons deal, I would have saved so much $$$ if I just went straight to forced induction. The only thing it was remotely worth it for was autocross, but still kinda pointless.
Cylinder pressure is almost always what ends up killing LE5's because the sleeves fail first. Boost is the most directly correlated parameter to cylinder pressure. Yes spark advance will increase cyl pressures, as well as high IAT's, but nothing as much as air charge pressure.
s/c it. my car took 10k miles on a 3.1 then 30k miles on a 2.8 before the clutch finally started slipping under boost. was running 14.0 @100 on the 3.1 and bad tires. car has 115k miles on the stock motor too
He's actually very accurate.
I guess I am talking from a daily driver/ reliability point of view.
I know that a number of folks on the forum have pushed the stock internals to some pretty impressive numbers with supporting mods. (which is very cool BTW)
I also know from first hand experience on my LSJ that if you start pushing things and you don't know what's happening with Temps, timing etc. you start blowing things up. Which is i am currently quite happy sitting with about 250 HP /232 TQ
That first blown engine made me a bit HP shy I guess.
I was simply talking about bang for the buck on a conservative SC setup .
My choice would be SC before anything else.
I agree, not really the point I was making though. Maybe I didn't spell it out that clearly.
In all my reading I can't believe I've missed that discussion.
Guess I need to read more.....
i drove mine everyday. proper tune, keeping it cool, and flowing is what is keeping mine alive
It'll raise the octane lower the intake air temperature and thus make more power. It's definitely beneficial but if I were you I'd stay away from it seeing as yours is a 2008. The more things you do the closer you are to the 250 whp mark and you're just asking for trouble there.
