Slight Rattle @ ignition and sometims during shifting?
Old 04-19-2008 | 08:51 AM
RBowe's Avatar
Hello all, I have a 2007 Cobalt SS 2.4L (manual) with about 23,000 miles on it. About three days ago i started noticing a slight rattle when i starting her up, and also when shifting between first and third gears from time to time. It is not continuous while driving, and I get no check ingine lights for feel no difference while driving. The noise kind of resembles the sound of pebbles in the muffler......This rattle is extremely aggrivating! Can anyone please help me or give me some idea as to what it may be?
Old 04-19-2008 | 11:48 AM
Turbo06Sedan's Avatar
chances are its your ECM cover, or ECM itself.
Take the cover off, and have a friend hold the ecm itself and start the car and see if it goes away.
its something vibrating, because going off of your post, you hear it sometimes, but not always.
so chances are its rattling from the vibrations of your engine (lower rpms = higher vibrations).
best bet to fix if it is your ecm itself, is to get a piece of foam and shove it behind the ecm.
i also notice my glove box is rattling more so now than before, so now i have to figure out a way to fix that.
Good luck to you.
Old 04-20-2008 | 02:01 AM
DecoyGSX's Avatar
I had a rattling problem too just like this.
Rear plate was loose a bit. 20 second fix.
Old 04-22-2008 | 08:45 PM
maverick0716's Avatar
Rear plate of the ECM? I have a very annoying rattle that I haven't been able to find so far.....during shifting at around 2500-2700 rpm........it's brutal. I would rejoice if I could find the damn thing.
Old 07-29-2008 | 05:00 PM
Ramphex's Avatar
so was it the rear ECM plate?
Old 07-29-2008 | 05:15 PM
bigworm's Avatar
tick tick ... rattle rattle
Old 07-29-2008 | 05:46 PM
Ramphex's Avatar
that helps
Old 07-29-2008 | 08:15 PM
Not on mine......rattle is still there.
Solaris99
28
03-15-2017 01:22 PM
bigdeertz
11-17-2016 09:41 AM
RaginChopsuey
10-27-2015 01:27 PM
jimbofug007
10-02-2015 12:06 PM
2009blackSS
09-30-2015 05:57 PM
Quick Reply: Slight Rattle @ ignition and sometims during shifting?
