so i dynoed today
Old 04-25-2008 | 04:09 PM
originaladrian's Avatar
Originally Posted by 06REDGT
$113 for 3 pulls
91.9 first one
93.8 second one
90.8 third one.:spam
print this thread out and go slap him with it.
Omega_5's Avatar
I'd normally say that his load cell is fucked.... but it seems to me that the cal file is probably buggered.
It's not understanding the relationship between RPM and torque.
Old 04-25-2008 | 04:10 PM
Originally Posted by ChevyRockstar
lol i didnt buy them um i forgot the guys name
first half was for u, second half of post was for OP, NOOB LOL jk
Old 04-25-2008 | 04:17 PM
ChevyRockstar's Avatar
GOD DAMMIT did it again
Old 04-25-2008 | 04:31 PM
06REDGT's Avatar
heres a video
Old 04-25-2008 | 04:34 PM
i knew it, it sounds like u used a dyno brake sequence on a non FI car. rookie mistake,. could be wrong but ur def right abt tht guy not knowing ****. please get ur money bak... u deserve it
Old 04-25-2008 | 04:43 PM
06black's Avatar
the numbers are a bit off, one would assume, however the man above is partially on the rite track.
those ugly and large rims are costing you power. i've seen 40-60hp lost due to brake size increases, let alone bigger wheels.
its not just weight that comes into play in this case, a larger wheel can be lighter then the smaller unit its replacing, yet you'll still lose power to the weight being farther away from the focus point (the CV) thus requiring more torque to initiate its rotation, and sustain it. a heavier and larger wheel simply makes this effect exponential.
with HP being a direct relation of torque and RPM this effect is self evident. the lesser power your car comes with will only make this effect more apparent.
i, however would go to a different shop, you should be down on power, but not that amount.
EDIT- is your car a stick or auto? the loss of power that torque converters cause would play into the power loss the of the rims as well.
EDIT2- the dyno run "sounds" like its legit, the load was steady and constant across the rev range. doesnt mean that the calibration is outta wack tho either.
Old 04-25-2008 | 04:44 PM
ifknrock09's Avatar
take it to a dynojet.
Old 04-25-2008 | 04:45 PM
those rims are hotswaps rite? there has to be someone that has a dyno with a few mods nd those. i cant see them costing u more than 5HP. but could be wrong.
Old 04-25-2008 | 04:46 PM
BlackSS05's Avatar
dyno day in NY $50 3 pulls numbers are uncorrected and much better than that. Sean with a 2.4 full bolts on dynoed like 170ish.
Old 04-25-2008 | 04:47 PM
  #36
06REDGT's Avatar
my car is stick and he did the pulls in 4th, the tires and rims are the same size as stock so that shouldn't affect anything.
Old 04-25-2008 | 04:49 PM
  #37
06black's Avatar
change the area in which the car has to rotate mass, and the return effect is exponential
i.e. wheels that are 5lbs heavier would effect power by several factors of 5....same goes for larger rims, size wise.
whats the weight difference then?
it could vary well be a massively flawed dyno, i'm simply supplying you with ideas as to why the numbers are so different.
Old 04-25-2008 | 04:55 PM
  #38
Omega_5's Avatar
I'm sticking by my theory....
Reasons;
The load is constant, which means it is applying load evenly though out the whole range... therefore it is reading the RPM/speed correct.
The torque number shown (131 ft-lb torque) is about right for the LE5. This tells me that the load cell is setup correctly, and reading properly.
Therefore, the system is simply failing to properly associate the torque value with the speed value and spit out a correct HP number.
I bet if you went and grabbed the raw data from that session, and manually entered it into excel with the correct RPM/Tq equation, that you'd get a reasonable HP number.
Edit:
The mustang dyno where I used to work did this last summer.... very similar situation... a hair puller for diagnosing, but a simple fix.
Old 04-25-2008 | 04:58 PM
  #39
07cobaltss's Avatar
dude he does not know what hes doing, go get your money back bro. i'll give you my number and you can give it to him... i'll bitch them out for ya.
Old 04-25-2008 | 05:05 PM
  #40
steddy2112's Avatar
I am pretty sure Konig hotswaps are actually lighter than the stockers.
Old 04-25-2008 | 05:07 PM
  #41
Zdeuce4's Avatar
$113 for 3 pulls
91.9 first one
93.8 second one
u got ripped off... i paid 60 for 2 and 3 woulda been like 75.. for that price i would expect a much better calibration or something
Reasons;
Edit:
131? about right? look at my sig for stock dyno...
  #42
Yeah even if they did , it shouldnt be a 70-80hp difference
Old 04-25-2008 | 05:10 PM
  #43
o3nisoaso3's Avatar
i put the car on a dyno dynamics dyno today and was i ever surprised, 93.8 max hp and 131 ft lbs tq, i thought my 2.4 would put down more hp than that.
wtf??? my lawn mower got more hp than that...
Old 04-25-2008 | 05:23 PM
  #44
Jimmys2007CobaltSS/C's Avatar
wait i sense a problem 93.8 whp????? on a 2.4 G5 GT>
Old 04-25-2008 | 05:59 PM
  #45
Omega_5's Avatar
Your comparing his location and dyno to your location and dyno.
A 20ft-lb difference is nothing to be too terribly worried about.... the 60hp difference IS something to be worried about.
Look at it this way... his tq is 15% off from yours.... his power is 60% of yours....
Big difference.
Old 04-25-2008 | 06:02 PM
  #46
IonNinja's Avatar
i bet he didn't offer any refund or the chance to come back at a later date did he? did you ask questions or maybe bring up that this doesn't sound right?
did any other cars dyno around that time that put out retarded numbers as well?
Old 04-25-2008 | 08:14 PM
  #47
06REDGT's Avatar
mine was the only one to dyno, he was just comin up with stupid answers why i got such low #'s, and i was so pissed at the time i don't remember what he said.
Old 04-25-2008 | 08:26 PM
  #48
idunn's Avatar
you all have to remember, its 93.8 canadian horse power... its different
Old 04-25-2008 | 10:20 PM
  #49
o3nisoaso3's Avatar
that explains it lol
Old 04-26-2008 | 01:20 AM
  #50
iLLmaTic3s's Avatar
numbers are way off. like chris said i put down 170ish with full bolts on..with the auto trans...shud of been higher..but w/e i dont care..jst my daily driver until i get my new camaro or c6 vette
Quick Reply: so i dynoed today
