so i finally dyno'd
Old 02-07-2007 | 07:50 AM
REDFOCZ's Avatar
Originally Posted by bc3tech
completely stock 2.4 dyno'd 145 recently. you added header, catback, intake and got, effectively, 21whp. that's actually damn good IMO.
145.7
Still very good numbers you got there
Old 02-07-2007 | 08:12 AM
Mase's Avatar
senior_brown, don't worry too much about the knock cause you only got it in the first run, probably cause your mounts were cold. The second and third run you didn't get any knock. Also you were running 91 octane, so if you put 94 your set!
As for the IDC, you did hit 106%, just get the bigger injectors and a tune.
You didn't go lean as there was no wideband hooked up, I would say you went rich from the IDC's. So if you lean it proper you could easily pick up another 10WHP.
BTW, this is Meisam, the guy with the Redline.
Old 02-07-2007 | 08:14 AM
OUTPR4MZ's Avatar
Pull Up Your Panties.. And Throw A Turbo On There
Lol
Old 02-07-2007 | 01:01 PM
senior_brown's Avatar
mmm turbo, guys you have no idea how many companies have asked for me to donate my car for a turbo development, i would love to, but i dont have another car to drive, and i drive a lot, maybe i should bite the cost soon and get a rental for a month
what size injectors come on the stock 2.4? should i go stock ss/sc or bigger?
Old 02-07-2007 | 01:06 PM
Psykostevo's Avatar
Yeah the knock is caused by higher IDC, and the stock injectors above 3rd gear are 90%+ and it gets worse from gear to gear. Get the 34#'s and we will figure out what harness you need soon.
Old 02-19-2007 | 12:47 PM
hey outpr4mz, yer cars lookin siccc wit it, im picking up injectors today, gonna do a tune real soon
Old 02-19-2007 | 12:50 PM
intense_SS's Avatar
pretty decent numbers for an na
Old 03-05-2007 | 06:26 PM
k, so i got the harness and the injectors put in today, 20 mins and i got a o2 sensor rich code (as expected) i gotto drive my mom to toronto and back in the morning and then im going by tag right after that to get it tuned.
ya think its ok to drive it like this?
Old 03-05-2007 | 07:04 PM
pjk91's Avatar
200ish+
Old 03-05-2007 | 07:37 PM
hoping to get 180whp/wtq
Old 03-05-2007 | 07:44 PM
  #36
CobaltBurst's Avatar
i would expect 165-170 realisticly but GL
Old 03-05-2007 | 09:03 PM
  #37
IonNinja's Avatar
better carry another set of plugs just incase
I personally would've installed them in the parking lot then got tuned
Old 03-05-2007 | 10:05 PM
  #38
extra set of which plug the o2 sensor?
im noit driving to anywhere tomorow anyway, just to tag and their real close
Old 03-06-2007 | 02:38 AM
  #39
IonNinja's Avatar
spark plugs
Old 03-06-2007 | 12:25 PM
  #40
i put the stock injectors back in
**** its cold outside, the car didnt wanna start this morning, so i didnt go to tag
i swapped them back and the car started 1st try, lotta smoke at first, then i took her for a nice boot on the highway to clear it up and its running clean again
gonna go to tag tomorow morning
06MetallicBalt
08-17-2021 03:40 PM
01-12-2016 12:01 AM
maliki778
10-01-2015 07:39 PM
Trav3480
09-28-2015 02:46 PM
09-27-2015 08:53 PM
Quick Reply: so i finally dyno'd
