Spark Plugs
Old 02-02-2012 | 09:16 AM
manny45's Avatar
Spark Plugs
Hey guys im supercharged so for those boosting... what spark plugs are you guys using? Also what are they gapped at? Im using the ones from ZZP the autolite xtreme performance, but wanna know if there are any better ones.
Old 02-02-2012 | 09:17 AM
jbenso4's Avatar
check out beck's build guide. I beleive its listed in there
Old 02-02-2012 | 09:56 AM
hhrfreek's Avatar
I am using the Autolites too. They are only one step colder, but that should be all we need. I gapped mine to .29
As per the Beck parts list:
NGK Copper Spark Plugs (Part# LFR6A-11)
When you look through the NGK plugs the number in the first series (6) denotes the heat range.
Old 02-02-2012 | 09:58 AM
manny45's Avatar
mine come gapped at .43 for my car should i lower it? It just honestly came to me... let me know what you guys think?
Old 02-02-2012 | 10:09 AM
jbenso4's Avatar
i just left the gap they came with
Old 02-02-2012 | 10:29 AM
user 72239's Avatar
I recently bought Autolites, gapped at .32 and so far no misfires. My old AC Delco ones were bad.
Old 02-02-2012 | 10:31 AM
manny45's Avatar
but that was on ur LSJ right? isnt it different for the LE5 or it really dont matter. Cause when im in idle it is good for most of the time but then randomly go rough and my arf hits 16.ish then goes back to normal... so I was thinking maybe its the plugs
Old 02-02-2012 | 10:32 AM
user 72239's Avatar
My Old LSJ was not Autolites. Cant remember which ones. but gapped at .34
my LNF is the Autolites.
Old 02-02-2012 | 10:34 AM
manny45's Avatar
so what you think drop it? Im at .43 what should i try to drop it to?
Old 02-02-2012 | 10:36 AM
user 72239's Avatar
Try .34, if that is still giving you issues drop to .32
I know stock gap is .35 for LNF/LSJ but yours is .42
Since your boosted, I would think it should be lower.
Old 02-02-2012 | 10:37 AM
manny45's Avatar
agh i see u think that is why i idle a lil rough sometimes?
Old 02-02-2012 | 10:40 AM
user 72239's Avatar
Could be, my idle was rough when I had the old spark plugs in. I was getting p0300 random missfire and p0302/03 for Missfire in Cylinder 2 and 3. No missfire so far and the idle is a tad bit better. Usually that has to due with the Tune. I am untunned with a Hahn CAI so I figure thats why my idle is off.
Old 02-02-2012 | 10:41 AM
manny45's Avatar
hmm alrighty well I will experiment and see if i run .34 how it feels can the car get damaged if I do a pull? after messing with the gapping?
Old 02-02-2012 | 10:43 AM
user 72239's Avatar
You will know immediately if the car doesnt like that gapping. it will probably sputter and die. I guess the only damage you could have is if the car goes lean and you have detonation. I wouldnt push it too hard.
Start it up, let it idle. Check your Interceptor and see if there any KR. Then slowly start to ramp it up.
Old 02-02-2012 | 10:45 AM
manny45's Avatar
I see... sweet thanks!
Old 02-02-2012 | 01:57 PM
bluebalt07's Avatar
NGK LTR6IX-11. I'm a 2.2 but plugs will be the same for you and I'm gapped at .028
Old 02-03-2012 | 06:26 PM
x-ception's Avatar
I have been running a gap of .036 on the NGK LFR6A-11 with the 3" pulley on a 2.4. I have no idea if they are any better than the Autolites but I have no complaints after running them for about 14-15k miles.
Old 02-03-2012 | 06:31 PM
c1_c1rca's Avatar
NGK LTR6IX-11 these are what im using to but im a 2.2 as well but i have mine gaped at .032
Old 02-20-2012 | 09:35 AM
manny45's Avatar
Hey guys where do u buy those NGK spark plugs at?
Old 02-20-2012 | 09:39 AM
user 72239's Avatar
ZZP sells em, but i think you can go into any auto parts store and have them ordered.
Silv3r's Avatar
For the mods you have at .43 i'd be surprised if you werent getting blowout. I'd try .32-.35.
Old 02-20-2012 | 09:49 AM
manny45's Avatar
Ya its weird I knew something was up.. cause when it idles it is a lil rough then also when im driving I give it a lil gas and then it studders a lil then its fine... im gonna see if thats the issue.
edited
The spark plugs on ZZP website say those NGK are only for LSJ is that ok ? ALso they have the regular NGK spark plugs and the NGK- V... So which is the one and is it ok to put spark plugs that are for LSJ in LE5?
Old 02-20-2012 | 08:25 PM
DFZ24's Avatar
Im at .42-.43 on the zzp liquid/air setup and no problems what so ever. Car ran strong.
I get my plugs of Amazon w 2day shipping free
Old 02-23-2012 | 07:44 PM
Dontstoprunning's Avatar
I'm running 2 step colder NGK iridiums
DarrenGC
12-24-2021 01:55 PM
agentirons
10-16-2015 02:11 AM
717ssbalt
10-02-2015 04:01 PM
CobaltSS 16
09-29-2015 01:53 PM
Adiaz1ss
09-26-2015 11:51 PM
Quick Reply: Spark Plugs
