Spark Plugs?? Best Ones For A NA!
Old 11-09-2007 | 10:53 PM
Projekt's Avatar
Just wondering what everyone recommends for spark plugs in a 2.4L NA. im planing to buy em next payday, A Part Number would also be perfect..i want the best "preformance" ones
thanks again CSS.NET community
Old 11-09-2007 | 11:00 PM
widebody_balt_ss's Avatar
no idea for a n/a but i bought 2 step colder for use with my n2o. and i have to say that the engine runs much smoother with them. they are made by zex. i also hear good things about ngk plugs
Old 11-09-2007 | 11:57 PM
g5mike's Avatar
I got bosch platinum 4s and they were not really any different from the delcos,some say ngk coppers are best for us.
Old 11-10-2007 | 12:00 AM
BigTizzle903's Avatar
sorry for jackin ur thread, but if it works good on a N/A wood it work good on a 2.2 too?
Old 11-10-2007 | 12:02 AM
Projekt's Avatar
i dont see why it wouldnt..
mike can u get me a part number..?
Old 11-10-2007 | 12:09 AM
CleanNFun's Avatar
Bosch Platinum are horrible spark plugs, dear god take those out. and The platinum-4 is just a marketing scheme it doesnt do anything, it can only fire off of one electrode
Old 11-10-2007 | 02:34 PM
BULLETSSMOKE's Avatar
Really? I've had them for a year and they've been fine. IF so, what should I change them out to.
Old 11-10-2007 | 02:49 PM
2WILD4U's Avatar
i have the bosch +4 platinum and they work great. no problem so far.
Old 11-10-2007 | 04:19 PM
hubes's Avatar
I had ngk iridium ix in mine for a while, they worked fine, I wouldnt say any better than stock though. I pulled them out to look at them and they all started life gapped at 0.042 and after a couple months 3 had opened up to 0.043 and the other had opened p to 0.045 so I put the stockers back in but didnt notice a difference, I still have the ngks for when the stockers go south. I dont think youll notice much of a difference if any by changing spark plugs unless the old ones are worn out
Old 11-10-2007 | 08:23 PM
Viper33884's Avatar
Yea, mine were probably the biggest waste of money ever...a guy I work with said they are good with higher out put ignition system....so don't really know. I think my next kind will be the NGK's.
Old 11-11-2007 | 10:25 PM
Projekt's Avatar
im not going with the bosh ones..the guy at canadain tire didnt even recommend them lol..whats the NGK ones i want?
Old 11-12-2007 | 10:50 AM
LS6Rally's Avatar
i put bosh's in my oldd 2.2 and it missfired from day one. i just used autolite platinums and never had a problem. im not sure what to use for a performance app tho.
Old 11-12-2007 | 10:53 AM
Edubs's Avatar
Guys, plugs aren't going to do anything to help you out. The stock plugs are perfectly fine and probably the best bet for your engine unless you upgrade to F/I or N2O. If you just have bolt-ons, just grab some stock AC Delco's and be on your way.
Old 11-12-2007 | 12:29 PM
ssbalt06's Avatar
lol its best if everyone that was wondering gives Edubs a "too shay"
Old 11-12-2007 | 06:25 PM
Jimmys2007CobaltSS/C's Avatar
how much are ngk copper spark plugs? they r recommended for the 2.4 s/c
Old 11-15-2007 | 07:37 PM
WhiteSSBalt's Avatar
Not a Sebring
^What he said.
Old 11-15-2007 | 10:51 PM
Eric304's Avatar
What about Autolite Extreme Plugs ... thats what i was thinking about going with when i got to about 60k??
Old 11-16-2007 | 08:37 AM
Edubs's Avatar
Stock AC Delco are better...
Old 11-19-2007 | 04:45 PM
averagewhiteboy's Avatar
What's the best range of mileage to change them at? This is my first new car. I have like 32k on it now. All of my other cars I just changed the mas soon as I got them so it didn't matter. But I figured it'd be about time by now...
Old 11-19-2007 | 04:54 PM
Edubs's Avatar
Technically, they're manufactured to last 100K, but we all know how these things go. Changing them every 30K is a bit neurotic, but it won't hurt anything. It's not like you're dropping a new engine in, this kinda thing won't break the bank...
Old 11-19-2007 | 05:00 PM
Exactly. I could care less about 30 bucks. I'm a sucker for 100% over-maintencing my car. haha
Old 11-20-2007 | 12:58 AM
kovich14's Avatar
I personally wouldn't use bosch or champion. Autolite, NGK, AC Delco are the best choices. JUST DONT USE COPPER PLUGS. The 2.2L and 2.4L come with double platinum plugs from the factory. These are not the cheapest and Chevy didn't use them just to waste money. The ignition in our cars is a "waste-spark" system; it fires twice as often as a conventional ignition system. It fires once on the compression stroke from the center to the side electrosde and AGAIN on the exhaust stroke from the center to the side electrode. The is caused by a polarity-reverse from the coil. DOUBLE PLATINUM PLUGS ARE REQUIRED for any kind of decent plug life. Your car will run on the $1.50 copper plugs, but the plugs wont last long due to the fact that they are pulling a double duty they were not designed for. The term "Double Platinum" means that both the side and center electrodes are platinum (stronger than copper). 2x platinum plugs will typically go 80-100K miles in GM cars.
DarrenGC
12-24-2021 01:55 PM
agentirons
10-16-2015 02:11 AM
717ssbalt
10-02-2015 04:01 PM
CobaltSS 16
09-29-2015 01:53 PM
Adiaz1ss
09-26-2015 11:51 PM
Quick Reply: Spark Plugs?? Best Ones For A NA!
