SS 2.4 ecu same as corvette ecu?
Old 03-20-2006 | 01:39 PM
celicacobalt's Avatar
If this is true then does that mean if a piggyback ecu is made for the corvette that the 2.4 ss can use it as well for tuning?
Old 03-20-2006 | 01:59 PM
articzap's Avatar
whered u hear that?
GTPprix's Avatar
Not a chance, sorry man LOL
Old 03-20-2006 | 02:03 PM
alleycat58's Avatar
LMAO who told you that?!?!?!?! Not a chance in hell they'd be swappable.
Old 03-20-2006 | 02:06 PM
DJNateGnau's Avatar
Yeah, They're Swappable.... BAHAHAHHAHAHAHAHAHAHHAHHAHHAhAHHAHHAHAHAHHA...paus es for breath, Then continues laughing....AHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA!!!!! !!!....Nate Died
Old 03-20-2006 | 02:15 PM
red_wing_2121's Avatar
Think about it man: Corvette - V8, Cobalt - L4.
There is no way they could have the same ECU.
Old 03-20-2006 | 02:20 PM
wesmanw02's Avatar
Just curious: Where did you hear this rumor from??
Old 03-20-2006 | 02:32 PM
im not sure i read it on the threads here somewhere that the 2.4 had the saem type of ecu my bad guys
Old 03-20-2006 | 02:37 PM
DJNateGnau's Avatar
No prob man. Well, whoever read it here MUST've been Joking. But still no prob.
Old 03-20-2006 | 02:38 PM
SS4ME's Avatar
Don't worry about it, just remember with every cylinder the ecu will need to manage it.
Old 03-20-2006 | 02:43 PM
c7015's Avatar
all laughter aside I think they have the same software with different variables (obviously) so once one is broken the other will be as well .. WopOnTour was saying something about it iirc and he is a very reliable source.
Old 03-20-2006 | 03:30 PM
c7015's Avatar
Hope this clears it up for the people still giggling
Originally Posted by WopOnTour
AFAIK both the 2.4 LE5 and the Z06s 7.0 litre LS7 utilize the "new generation" E67 ECM, (3900 V6 and 4.6 supercharged as well)
https://www.cobaltss.net/forums/show...37&postcount=5
Old 03-20-2006 | 03:33 PM
yeah thats what i saw that made me think this, again sorry about the confusion im still new to ecu tuning since ive never actually done it yet on my cars and im learning still.
Old 03-20-2006 | 03:40 PM
GTP's Avatar
GTP
Well I don't think its far fetched..could use the same generation of coding and/or hex (beta). Don't know much about the inner workings but they are probably reasonably similar.
Old 03-20-2006 | 04:11 PM
GTPprix's Avatar
Lets put it this way, not even close
Old 03-20-2006 | 04:17 PM
DJNateGnau's Avatar
Ah ok, I see. Same computer, Just different programming. I can see where you'd get confused.
Old 03-20-2006 | 04:22 PM
GTPprix's Avatar
Ok again, NOT THE SAME COMPUTER AND NOT THE SAME PROGRAMMING
Old 03-20-2006 | 05:03 PM
GTP's Avatar
GTP
Well for whatever the question was worth I think that (GTPprix) solved the issue.
Old 03-22-2006 | 07:32 AM
DanM's Avatar
I do not believe that the Vette and Cobalt are using the same engine controller. HOWEVER - those of you that called the guy stupid for even suggesting it are pretty wrong. GM's new family of engine controllers is very flexible and can be used for many things. The same controller is being used out there already for 4cyls, V6s and V8s. Same hardware, different programming obviously. Obviously you couldn't just take a Vette controller and plug it right into a Cobalt and go, but if you could change the software, the hardware would be quite compatible (which was his question, I believe).
Old 03-22-2006 | 01:26 PM
WopOnTour's Avatar
Actually YES
The 2.4 Cobalt and the LS7 Vette both use E67 boxes SO THE HARDWARE ITSELF IS IDENTICAL (the SS/SC uses a P12 PCMs shared with the Colorado and Canyon trucks)
In fact if you look and compare their wiring schmatics they have a LOT in common...
However as Dan mentions the flexiblity of the latest 32-bit control units means they can be setup to function differently in different platforms and powertrains
WopOnTour
Old 03-22-2006 | 01:31 PM
GTPprix's Avatar
Uhmmm NO the LS7 uses an E38, and the other new LSX series use an E40/E38.. The Cobalt uses an E67 WHICH IS NOT COMPATIBLE WITH THE OTHER CONTROLLERS! How on earth are you getting they are the same ECM?!!? Hell anyone off the street could see the E38 for the LS7 has TWO connectors and the E67 for the 2.4L (and others) has THREE LOL
Old 03-22-2006 | 03:39 PM
DanM's Avatar
I thought the Vette was an E38 as well, but ah well. Point is most of these things are at least somewhat cross-compatible, so it's not far-fetched at all.
Old 03-22-2006 | 04:01 PM
GTPprix's Avatar
Yes and no really.. The OS's are completely different, calibration segments of course and the outputs are of course different. I'll have to pop open one of the E38's I have here but I'm 99% sure from what I remember that the Microcontroller isnt even the same although they both have 2MB of flash now..
Old 03-22-2006 | 04:02 PM
plyboy-illest's Avatar
i really dont think so ....
Old 03-22-2006 | 04:10 PM
DanM's Avatar
Agreed, I meant more from the perspective of the original poster's comment. Ie if the Vette and Cobalt both used an E38, could you take tuning kits/hardware/piggybacks/practices/whatever that worked on the Corvette and apply them (at least in principle) to the Cobalt. I think the answer to that is probably yes, with some caveats of course.
