SS 2.4L Engine Upgrades?
#177
#178
actually NJ i just went out there and looked at my air/fuel guage and no rev is about 15.5 abd full boost is about 13 roughly IM GUESSING from looking at the guage and what i remember it being at so could be off some.
i appericate it anyways Mr. *******
#179
****...you drew me back into your idiocy...
#183
I'm hungry and my head hurts from reading your posts (I'm the official second victim).
Enjoy tuning with your narrowband gauge.
#187
And sorry but you add forced induction to have your engine run better than it was...not worse. So no, it's nothing to be proud of.
I don't even want to know how you are "attempting" to tune.
HAHAHAHAHA
#188
i back talk? what is this 5th grade. lol dude im not gonna have someone bash me when they dont even know who i am and probley wouldnt man up to it IRL. now i was having a "civilized" conversation wtih NJ. LOL
#189
Maybe you're not that smart. I've been laughing at you since my first post made on this thread.
#190
lol i thaught u were going to eat chicken? Poof bitch be gone
u just cant resist can u LOL anyways cya
im not banned yet? crist im tired of typing screw it.
#193
Higher compression can always make more power in any situation, but not safely. Because pressure changes with temps and conditions, when you boost high, but use a lower CR, any major climate/condition changes will create less CFM automatically or more depending, so it will keep it safer. High CR with boost you have to tune more conservatively, less timing, etc, to make sure you don't knock like a **** under conditions that were not present when you made the tune. That whole thing didn't really make that much sense, but it's true LOL.
There is another big factor on detonation: combustion chamber and piston top design. Thin, ridged areas tend to heat up and become a heat source to cause early ignition (knock). Smoother structures reduce this tendancy. Cooler exhaust valves help too. The Ecotec is very good in this respect, which makes it nice for FI - I've read that it's very forgiving, and not particularly prone to knocking.
I'll find out soon enough....
yes, but the smaller the turbo (dependant on bearings and efficiency also) the mroe heat it is going to generate at a given flow, so if you are running a small turbo at 6 psi, you are still gonna want to intercool because it will be considerably safer. You may lose boost, but you are also able to tune alot more aggressively.
I'm enjoying these side discussions on this thread - lots of good technical info being considered here!
-J-
Sorry, but this Cherokee grew up hearing "damn injin" way too often - I can't know what it's like to be in your shoes, but I had a little share of it.
We "minorities" stick together!
He plugs it into his butt and what comes out ends up in his posts...
#194
Very good, and valid point. However, there is a trade-off in lag. I'm going to try a low-boost kit without an intercooler (I've had 2 cars with this configuration from the factory) just as an experiment. All I'm out if I decide to add an intercooler is the charge pipe - total cost will end up the same as if I went intercooled to begin with. For sure, such a system is inherently limited. If done properly it works quite well and makes an excellent street driver. But it has no expansion capability without adding the intercooler. BTW, Chrysler sold an intercooler kit and control valve to increase the non-intercooled 2.2 Stage 1 factory turbo cars from 146 HP to 175. They used the same turbo with both with only a change in the boost controller valve (and, of course, the intercooler).
#195
Lewis don't waste your breath. He knows all and sees all! Actualy all hes prooved is hes totaly clueless and that hes a racist ass monkey! (Hmmm, lets see how can I hurt a black guys feelings......OH I KNOW I'LL CALL HIM A ******! WOOHOO GO ME!) Squeek dude I was on your side but you done crossed a line! First you ask for help then say you don't need any then you try to flame those who tried to help you and now your resorting to racial slurs? What the hell is wrong with you? Seriously do you have some A.D.D. issues that we should know about? Your beyond help! And from your last post you seem to want to be banned! Its easy BAN YOURSELF! Hell you have our permission to PERMA- BAN yourself! Its easy to JUST LOG OFF AND DO NOT COME BACK! You and your raceist crap are NOT welcome here.
End rant.
End rant.
#196
I'm not looking to race, just get some go here at a Mile High in Denver. Plus it's an auto, and getting very crazy would mean a peformance build on the tranny so it would survive.
End rant.
End rant.
#197
That's exactly the territory I'm headed into. Although since we will be using a piggy-back to decrease ignition under boost, we may push it toward 7-8 as long as we get no detonation or knock sensor triggers.
I am planning on adding FI to my 2.4, but was going to try and use the stock PCM.
#198
One of the basics of turbo theory is that detonation can be moved to a higher boost (i.e., you can run more boost without knock) if you back out some timing under boost. To make the stock ECU do this, HPTune would have to be used to reduce timing over a given range. That means that timing would be retarded even when not on boost.
The best solution is something that reads a boost sensor and adjusts timing accordingly. This was actually easier on vacuum advance distributor cars where boost can be fed into a modified vacuum advance to retard the timing when pressure comes up. With digital engine management, a piggy back can be used to "trick" the stock ECU into backing off timing under boost. I'll use the unit Alpine uses (I'm spacing the name right now...).
Here's a good article on a boosted 2.2 that uses this approach:
http://alpine-developments.us/Alpine...2520cooker.pdf
#199
I'm sorry I used the "N" word but it was to illustrate what pip squeek was probly thinking. I already talked to Adam about this he called me and let me know the new lows that pip squeek had sunk to and I didn't believe him. Sorry Adam you weren't kidding!
Squeek as far as I'm concerned your just a raceist ass monkey. We try to have discussions that bennifit all the members of CSS.NET but it would seem that concept is beyond your grasp. Adam may not get pissed at the racial **** but I sure do! He's a very good friend of mine and its BS that you think you can talk to him, or ANY other members this way! Call me a snitch I could care less but I reported your little hind parts to the mods so hopefully you'll get that ban you were looking for.
Hmmm, I just noticed how Squeek has no place to even input rep....wonder why? Ohhh hes BANNED!
#200
Some on the board are surely getting tired of hearing me say this, but what scares me about HPTune and the stock ECM is that it has no way to "see" boost (no boost pressure input).
