SS/SC front and rear lip bolt on to 2.4?
I saw a few threads that just barely touched on this but, can you buy the SS/SC Front and rear lip and bolt it on to the stock 2.4 body kit. I assume you ahve to take off the Lip off the rear bumber but is this possible? Thanks
not it will not "bolt right up" all the holes are there on the bottom of the bumper to hook the lip to but you need to zip cut long rectangles in your bumper for the tabs to slide into and put these metal clips in behind to keep it tight to the bumper..
If you want a direct bolt on SS/SC lips then you have to use the front and rear SS/SC bumper covers. This is the only way to have direct bolt on.
All bumper covers are interchangeable on all models. You can take an SS/SC and put it on a 4 door sedan. And you can take a 4 door sedan bumper covers and put them on an SC
DANRICKARD
10-01-2015 12:08 AM
