supercharger
Old 01-31-2012 | 03:25 PM
Red08Sport's Avatar
supercharger
So one of the guys in the club had a accident and his car is totaled. I plan on getting a lot of his stuff.
Now I'm wondering about cutting the rib of the belt to fit the altenator. Is it safe? Or should I pick up that from him as well.
And also cooling mods. He's got a stage 3 heat excanger, option B, dual pass. Should I get those as well. I've been told that you can never have enough colling mods. But that's been by the LSJ guys. I only plan on running a 3.1 pully for now.
Old 01-31-2012 | 03:47 PM
user 72239's Avatar
Cutting rib is bad, buy all Tylers stuff. Cant have enough cooling mods.
Old 01-31-2012 | 03:58 PM
Red08Sport's Avatar
Ok kevin. I should also buy your stage 3 heat exchanger and run both.
Old 01-31-2012 | 03:59 PM
evofire's Avatar
On the 2.2 motor, all the pulleys are 5 rib. If you want to use a 6 rib belt, you must swap to an LSJ alternator, ac compressor, and crankshaft pulley. It is a lot easier and PERFECLTY fine to trim a rib off of the belt.
The way I did it was to hold the belt on the floor (with something soft underneath it) and made the initial cut INTO the belt, and then had a buddyy hold the razor blade in place as I used two hands to pull the belt through the sharp blade.
Old 01-31-2012 | 04:01 PM
user 72239's Avatar
sure. might as well run a normal HE, and 2x ZZP S3. Cooling mods!!!!
Sorry, mine is spoken for by someone in the club.
Old 02-01-2012 | 11:37 AM
manny45's Avatar
I went with the 6 rib. U might wanna talk to trent idk if he would wanna cut the rib off he doesnt like doing stuff like that... The chances of something going wrong may go up... who knows many people here have cut off a rib and done it and idk if it messes up later on as for me no problem with the belt and that. Cooling mods just with a stage3 intercooler ur good. Im on a 2.9 and its fine. But more cooling is always better haha.
GaryGibblez
01-14-2020 10:35 AM
RaginChopsuey
10-27-2015 01:27 PM
brandon04
10-21-2015 07:04 AM
z28addiction
09-28-2015 12:03 AM
medic710
09-06-2015 08:53 PM
Quick Reply: supercharger
