Supercharger kit for the 2.2/2.4L from zzp
Old 02-13-2010 | 09:18 AM
  #201
riko540's Avatar
Originally Posted by glen229
How are they gonna tune 08's?
IDK they must have found a way. Either that or you'll have to tune it yourself.
Old 02-13-2010 | 12:18 PM
  #202
xander40's Avatar
great question, i forgot about this. maybe they won't tune us and we won't have to pay the extra 100 bucks we do for the TB adapter and have to get private tuning
Old 02-14-2010 | 09:31 AM
  #203
slobalt08's Avatar
Trifecta probably
Old 02-14-2010 | 09:54 AM
  #204
HyperMuffin's Avatar
08s might get a discount since they will probably have to go through trifecta or someone else for a tune.
Old 02-15-2010 | 01:53 AM
  #205
Mr.N00bLaR's Avatar
Where did it say it included or even offered tuning of any type?
Old 02-15-2010 | 11:30 AM
  #206
DFZ24's Avatar
Pricing for stage 1 will be $1999.99, stage 2 a little more.
with this price i'm now debating which one to go with
i was going with the sc because i thought it was going to be a little cheaper and i have the psi right there but now idk which one to go;
sc or tc
what would be the advantage and disadvantage?
Old 02-15-2010 | 11:38 AM
  #207
blackbolt89's Avatar
isnt the stage 1 turbo kit from them about the same price as the stage one s/c?
id rather get the stage 1 turbo and buy an intercooler aftermarket.
Old 02-15-2010 | 11:44 AM
  #208
dragonkingg5's Avatar
Yeah the 2.4 turbo kit is 2k price also. But in the specs for this sc kit, it says it increases hp by 75 on stage 1 I think. Got no clue how on 3.4 pully, stage 1 tubro does about 40-60hp.
Old 02-15-2010 | 11:51 AM
  #209
Mr.N00bLaR's Avatar
https://www.zzperformance.com/cobalt...new1.php?id=58
and
https://www.zzperformance.com/cobalt...=922&catid=143
Is 40-60 a real world observation?
Old 02-15-2010 | 12:02 PM
  #210
Yadovosky's Avatar
Nice, Well better start saving for this....
Old 02-15-2010 | 01:28 PM
  #211
wesg631's Avatar
Supercharger is a little easier on the motor instant power no lag,turbo has lag but can make insane amouts of power
Old 02-15-2010 | 02:59 PM
  #212
xander40's Avatar
it says the stage 1 turbo adds 60-80 hp now.
Old 02-15-2010 | 03:08 PM
  #213
PSHHH's Avatar
and it cost more for having a 08+ id rather just get the turbo setup more then likely your gonna swap out the s/c anyway eventually...is the TVS possible on 2.2 and 2.4L?
Old 02-15-2010 | 05:44 PM
  #214
HunterKiller89's Avatar
yes. Anything you can do to an LSJ you can do to a 2.2/2.4
Theyre all ecotecs with the exact same external dimensions
Old 02-15-2010 | 05:52 PM
  #215
riko540's Avatar
Yes, however the auto guys will run into fitment issues due to the engine being tilted slightly forward.
Old 02-15-2010 | 06:05 PM
  #216
good point. Even after cutting the frame a bit, i still couldnt ft my 3.4" on.
Old 02-15-2010 | 06:18 PM
  #217
CordiaDOHC's Avatar
The auto guys might as well consider there not being a stage 1 kit.
Or consider the stage 2 kit as their stage 1
Old 03-03-2010 | 06:14 PM
  #218
Mindrot's Avatar
It's here.
Old 03-03-2010 | 06:15 PM
  #219
kissrocker52's Avatar
ya so stoked will it work for a auto
Old 03-03-2010 | 06:28 PM
  #220
Mindrot's Avatar
I would imagine so. They don't list much information about it considering they just put it up today. Let's get more info for those here that are interested!
Old 03-03-2010 | 06:32 PM
  #221
CordiaDOHC's Avatar
Yeah still waiting for more info. Though im waiting for a pm back from matt on some other stuff. lol kind of hope he takes his time so I dont jump on this! Ive been trying to talk myself out of modifying a 20k mile car that heavily and just repairing/modding my eclipse instead.
Old 03-04-2010 | 06:35 PM
  #222
slobalt08's Avatar
Does this kit come with a boost gauge or no? I could of sworn reading it did, but now I don't see one. Also if it don't, will I be able to use the stock boost gauge on my 08 2.4? Someone was telling me it wouldn't work for them on their G5 (the boost gauge) so I want to make sure it will work for me.
Old 03-04-2010 | 07:35 PM
  #223
no stockers will work. Buy a $40 mechanical gauge...theyre more accurate anyway
Old 03-04-2010 | 07:41 PM
  #224
Jn2's Avatar
Jn2
The kit includes:
M62 Supercharger
ZZP pulley system
Lower intake using Laminova intercooler
LSJ throttlbody
39# injectors (base kit)
Cooler NGK spark plugs
TB adapter harness
MAF extension
2 bar MAP sensor
Serpentine belt
ZZP intake tube with K&N filter
ZZP Alternator spacer
ZZP idler stand with idler pulley
Valve cover breather
Bosch IC pump
ZZP heat exchanger
All nuts, bolts, gaskets, fittings, and hoses needed
pulled fromt here site, ZZP if your reading this, add a option to remove the 2bar map sensor for the 2.2...we dont really need it, its just a option and vince can tune with out it
Old 03-04-2010 | 07:52 PM
  #225
slobalt08's Avatar
Ah ok. Is there a how-to to intall the mechanical gauge?
Originally Posted by Jn2
The kit includes:
M62 Supercharger
ZZP pulley system
LSJ throttlbody
TB adapter harness
MAF extension
2 bar MAP sensor
Serpentine belt
Bosch IC pump
ZZP heat exchanger
That;s a sensor though i'm just asking about the gauge
Quick Reply: Supercharger kit for the 2.2/2.4L from zzp
