Supercharger/Manifold for the 2.4?
A thicker head gasket will change your compression by like .01 or .02. Too thick and you're going to be blowing gaskets all the time. You're talking 1/1000s of an inch difference in thickness. A head gasket isn't going to even get you a .1 drop in compression ratio.
Best bet for boost is forged low compression pistons around 8.5:1 for lots of boost or 9:1-9.5:1 for a decent amount. We're at 10:1. Don't know about 4 bangers but forged low compression pistons run about $400-500 for a 355.
Originally Posted by Brandon97Z
The manifold off the 2.0 should bolt up.
Someone's gotta be the FIRST!!
HTH
WopOnTour
VVV Here's what you get in the GMPP kit VV and the instructions for installlation are in the Build Book on the GM Tuner site
For more boost the 2.4 needs a set of lower compression pistons, although a thicker head gasket would help a little bit. Not sure about the 2.0 question though. Maybe @ 350whp the internals would need some work, but thats just a guess don't take my word.
Originally Posted by articzap
9:1 if im not mistaken
Originally Posted by jaslowyota
Originally Posted by Cobaltlover22
what is the CR of the 2.0l supercharged cobalt
http://media.gm.com/us/powertrain/en...ec%20(LSJ).pdf
http://media.gm.com/us/powertrain/en...E5)%20rev2.pdf
However, IIRC the GMPP kit for the 2.2 has a slightly larger pulley to reflect the fact that the 2.2 is 10.0:1 CR.
http://media.gm.com/us/powertrain/en...ec%20(L61).pdf
Close enough IMO
WopOnTour
#37
Originally Posted by Brenn8402
so how much is the gmpp kit?
BTW: The GMPP kit includes the super efficient Laminova cored exchangers in the intercooler, BUT does NOT include the electric CAC pump, reservior, hoses or radiator (as used in the 2.0 LSJ)
The lines are just plugged on the 2.2 kit
HOWEVER
There's no reason why it couldnt be added, with a little ingenuity.
Would allow you to run quite a more boost even at 10.4:1
WOT
#42
Your right it does look like it would bolt right up to the 2.4. Thats awesome. well if I can find someone who can tune this ecu to work with it i'm golden. I already have the motor torn down with a new bottom end going in. I was going to fab my own turbo kit but if that blower bolts up like you said it would than I will just do that. How much boot can that blower crank out?
#47
Not sure if GM will help but I am in the process of putting my short block back together with a forged crank billet rods and billet pistons. I was going to do a custom turbo kit and post it up but now I am just going to do the blower if it bolts up right. I will most likely get it ported first though. Anyway I will keep you all posted on the build.
#48
ok i found a supercharger off of a 2.0 for like 900 dollars. so if anyone knows what needs to be done to our engine to make it be able to handle the boost that the 2.0's supercharger puts out let me know in a pm or on this thread as soon as you can... id like to know ball park prices also if possible. thanks
#49
here is 1 problem with the 2.0 s/c on a 2.4 , also its something on the 2.2 that needs to be modified
there is a engine lift bracket that is bolted to the head , and to clear part of the tensioner set up , you have to chave that off the head
now the 2.4 head for the cam timing is very thick to clear the bulk of the adjusters , this also might cause more of a issue on the 2.4 , than it does on the 2.2
gravana tuning , has a turbo'd solstice(same 2.4 motor) it dyno'd in the 250whp range
being the compression of the 2.4 , premimum fuel is a must , and you must run the car on the very rich side to keep detonation down
atleast untill HP tuners or someone comes out with a program to change setting inside the pcm
#50
