Thank you tax return
I just got my tax return so the fun begins I should be gettin my spec stage 3 plus clutch and motor mounts today installin it Monday at wrk I sold my nitrous set up yesterday I'm ordering supertech valve springs arp head studs zzp stage 2 turbo Kit with 60 lb injectors hopefully I'll have it all done within the nxt couple weeks prolly gonna start off with 12psi n work my wAy up hopin for 350-360 whp
Its been known for awhile the 2.4's can handle to around there, theres a gm spec sheet floating around to back that up. Not to mentioned ZZP is pulling 356whp through an auto tranny 2.4 cobalt. Stock internals except 78lb valve springs with multiple track passes
im not doubting you im starting a build on my 2.2 and i just wouldnt want to see you blow it over a few pistons and rods
the 2.4's powdered steel rods will not handle that stress for long. the cast pistons have been known to take abuse if you keep knock at bay and dont run too lean. the last spec sheet i saw, the rods were rated to 250hp
Where did you read that? Everything I've seen shows that the LE5's internals are good to low-mid 300's and 8 psi or more. People push 360 hp through the Solstice/Sky LE5 with Hahn's S3 kit.
i really doubt the powdered steel rods are rated that high. remember just because we can go that high doesnt mean its rated for safety at that high of a power level. lol. and i can assure you none of the pistons in these cars are meant to go past 300hp
