Traction Control
Old 07-01-2007 | 06:34 PM
Jimmys2007CobaltSS/C's Avatar
yea it had happen to me when i first got it the t/c light came on and when u shift from park to drivee it jerks...but it hasnt hapen in like 3-4 months now i had my caar for 9 months
Old 07-02-2007 | 02:25 AM
06sscobalt's Avatar
well i do have aftermarket rims i dono if that will have anything to do with it. but mine hasnt done it for a few months but it always did it at random times
Old 07-02-2007 | 07:26 AM
Blankobalt06's Avatar
then if it might have something to do with the MAF...could it be our intakes?
Old 07-02-2007 | 07:40 AM
reed's Avatar
My 2.2 would do it whenever it was raining and I took a corner while giving it alot of gas. The light would come on and it would shift hard as hell. Then when you shut the car off and restarted it was normal again. That is the main reason I got my B&M shiftplus! It hasn't done it since I put it on.
Old 07-02-2007 | 11:21 AM
celicacobalt's Avatar
it has somethingt o do with our intakes cuz my friend with a 2.2 never had this issue but after he cleaned his intake it happend.
Old 10-25-2012 | 06:23 PM
mckisson's Avatar
T/c Light
My light usually kicks on when i accelerate and the it starts to shift real hard.
Old 10-25-2012 | 07:49 PM
06Cobalt2.4's Avatar
I'm gonna go ahead and assume your Check Engine Light (CEL) is Illuminated. I haven't read through the other responses on this thread, but I had the same T/C Light problem for a long time, before I learned how to fix it. First off it's on because of a sensor or solenoid malfunction.
To my knowledge, I've got 2 diagnosis [plural w/e) for the problem.
1. Mass airflow sensor is faulty.
Here is a thread I pasted in relating to that.
https://www.cobaltss.net/forums/2-4l...g-hard-281273/
A new mass airflow sensor off eBay can be bought relatively cheap ~$30-$40
2. If you pull a P0128 CEL code with an OBDII scanner that you can rent from O'Reilleys Auto Parts (for example), it will say (either one or both): Intake Camshaft Actuator Solenoid or Exhaust Camshaft Actuator Solenoid [They might say over-performing] In either case, one or both are faulty and this is a common problem for our cars.
[] I would reccommend pulling the engine codes, and update us as to what you find. If you fall into either of the 2 diagnosis listed above, I can definitely help you the entire way through the repair process without spending premiums at a shop. []
Old 10-26-2012 | 01:35 AM
06cobaltss2.4's Avatar
I'll second that on the CMP Solenoids. My Intake solenoid had an open circuit (bad solenoid) and every once in a while my transmission used to do that. I'm pretty sure it shifts hard because it goes into a "safe mode" where it raises line pressure to prevent slipping in the transmission due to an increase/ decrease in engine output. I would definitely check to see if you are throwing a code for the solenoids, or MAF code. If it's a MAF code they also have MAF sensor cleaner at any parts store, it actually does help a handful of times it has for me on various vehicles. It's cheaper than a MAF sensor and should be cleaned every time you change air filters anyway.
Old 10-26-2012 | 02:08 AM
Wow, your name is really close to mine haha...
Old 11-01-2012 | 06:25 PM
https://www.cobaltss.net/forums/how-...6/#post6772267
Old 11-01-2012 | 07:47 PM
  #36
Here's my official How To Guide link: All Engines HOW TO FIX: P0010-P0015, P0100-P0104 CEL FIXES T/C light, hard shifts problem - Cobalt SS Network
Old 12-03-2012 | 08:06 PM
  #37
Dj_Translator's Avatar
I had mine into the garage and they replaced the exhaust actuator solenoid. I have yet to get the t/c light to come on
Old 12-04-2012 | 12:36 AM
  #38
I hope you didn't have to pay a ton of money! My how-to guide makes labor free and easy.
Old 01-13-2013 | 12:26 AM
  #39
laurapontius's Avatar
Originally Posted by Dragonsfire12345
mine does it to but the abs light comes on also
Same problum for about a year now
Old 01-15-2013 | 01:47 PM
  #40
shortyheldberg's Avatar
My 2.4 did that a couple of years ago and was driving me nuts with the hard shift and my trans was tuned for a harder shift. Well what happened was all of this electronic stuff is a pain in the a##. It got so bad that when I would hit the gas hard the light would go on took it to the dealer and it ended up being a bad cam sensor.
Old 01-19-2013 | 03:13 PM
  #41
Rob O's Avatar
This happened to me after Installed my K&N typhoon, ended up being a loose wire going to the maf.
Old 01-21-2013 | 05:30 AM
  #42
lancethrustbone's Avatar
06Cobalt2.4 is correct.
You will have very hard shifting and your traction control will disable if you have a MIL case. Some of the codes will be thrown but not set off the "check engine" light on the first occurrence. They may end up resetting before a second occurrence and wont end up setting off your "check engine" light
I've had this happen to me but that was my doing when I was first calibrating my MAF tables. Once I dialed them in it quit happening. I also had my TC light come on when both of my cam shaft solenoids were failing. I've since had both replaced. In the case of the solenoids those disabled traction control but did not result in hard shifts. In the case of MAF, that did result in hard shifts. If you have an aftermarket intake you may notice this happen. If you don't have an aftermarket intake then do as 06Cobalt2.4 is suggesting and get your engine checked for thrown codes. Your cam shaft solenoids should be covered under the emissions warranty if your powertrain warranty is over. They will fight you on this though.
I had my first one replaced under powertrain warranty and just replaced the exhaust sensor on my own when that failed about a year later since the solenoid is cheap and super easy to replace. I didn't feel like leaving my car with them for 2 days to do a job that can be done in less than 2 minutes.
Old 05-10-2013 | 11:33 PM
  #43
guppy41's Avatar
had this happen and heard a knocking coming from te tranny... i just pull over shut my car off and restart it and it goes away... you can manually turn your t/c off while driving by shifting to low and back up to drive
RaginChopsuey
10-27-2015 01:27 PM
SSLOW06
10-01-2015 07:21 PM
ColonelMustard
North Pacific
09-29-2015 03:02 PM
09-26-2015 06:44 PM
Coballin13
09-25-2015 08:43 AM
Quick Reply: Traction Control
