Trouble with Injen?
Old 05-19-2006 | 08:43 AM
k2kwj's Avatar
i disconnected the battery.
Old 05-19-2006 | 09:23 AM
PursuitGT's Avatar
I installed my Injen CAI a long time ago and did NOT disconect the battery. Havent seen a single problem yet.
Old 05-19-2006 | 02:31 PM
k2kwj's Avatar
No CEL
okay i think that i might have figured something out but if this sounds completely off the wall then please correct me. my cel came on last night after running my car really hard at the track and i figured it was something to do with the intake. it really pissed me off and i tried a few things to try and get it to go off last night but nothing worked. when i woke up this morning i thought hey maybe if i disconect the battery it will go off because it will reset everything and it worked so maybe if everyone who has their cel on disconnects their battery for a while the light will go off.
Old 05-19-2006 | 04:06 PM
DARK AGE 53's Avatar
Originally Posted by jerryg
ok guys same thing happened to me whats going on is when you put your intake on it was way to oiled and getting into your mass air flow sensor. little by little it will gradually get worse so my suggestion is take off your intake wash it and remove all of your oil thats on it. if problem stills remains your maf might be ruined
Maybe not, try using Blue Shower ( Electrical Contact Cleaner ) on the wires before buying a new one....also, guys have used a q-tip dipped in rubbing alcohol to remove the oil from the wires. When using the q-tip you need to use as little pressure as possible on the wires...do a search on the net and you'll find plenty info on this.
Sometimes that works and sometimes it doesn't, there's times you'll need an OBDII system tester to turn off the cel...if there's a problem the cel will come back on ASAP.
Old 05-20-2006 | 08:51 AM
k2kwj's Avatar
well mines still off and its been almost 24 hours and about an hour and a half or so of driving.
Old 05-20-2006 | 01:27 PM
fukuhos's Avatar
my light came on after some heavy rain storms but i got the code erased i didnt notice and type of water on the intake but its ben stayin off for awhile but i also didnt disconnect the battery but its ben runnin better sence i erased the codes only problem i had if it comes on again ill order a aem dry filter and see what that does and if nothin ill go back to stock im gettin a turbo anyway so who cares about an intake lol
Old 05-20-2006 | 10:39 PM
k2kwj's Avatar
horsepower is horsepower even if its only 2 or 3.
05-28-2022 03:47 AM
717ssbalt
10-02-2015 04:01 PM
jmelton327
09-25-2015 09:44 AM
irvin316
09-25-2015 12:41 AM
budah93
09-23-2015 02:26 PM
Quick Reply: Trouble with Injen?
