turbo auto question
Old 05-08-2006 | 05:36 AM
snobird's Avatar
turbo auto question
hahn is making the turbo and im hopeing to buy. but my question is will it be able to be used with the automatic will they have a specail kit for the automatic or whats the deal for the auto or is it too soon to ask? thanks
Old 05-08-2006 | 06:54 AM
snowbred's Avatar
they are making it available for the auto aswell, but we might have to upgrade a few things.
Old 05-08-2006 | 06:23 PM
Dragonsfire12345's Avatar
my friend said we would not have to upgrade nothing. in the tranny. he boosted a could of 4T45E's already and everythings fine
Old 05-08-2006 | 06:25 PM
snowbred's Avatar
Im sure it will run fine but it will shorten the life of the tranny, hahn said that we will have to upgrade a few things so we could run boost on the auto reliably.
Old 05-08-2006 | 06:33 PM
oh ok
Old 05-08-2006 | 06:37 PM
D4u2s0t's Avatar
it depends on the level of boost... after a certain psi you will need to upgrade.... auto's are fine with a turbo though, most of the super fast turbo cars are auto.... ie, the cobalt running 9's is an auto...
Old 05-08-2006 | 07:28 PM
RaineMan's Avatar
I think we'd be better off running a supercharger with our 4T45... with only the four gears we'd probably fall out of boost range when it shifts... a supercharger would provide more consistant boost.
From GM's own stats the 4T45 can handle 205 lb/ft of engine torque on a daily basis with no problems. We're at 160ish stock... so that's 40 more lb/ft before we even need to worry about any upgrades. The G6, Malibu, and Vue use this tranny... and they're all running more power than we are.
Old 05-08-2006 | 10:30 PM
sloNlow's Avatar
Does the 3.9 use the 4T45E? cause it's well over the 205 lbs/ft rating. The 3.5L is at that limit from the factory.
Old 05-08-2006 | 10:36 PM
snowbred's Avatar
no only the 3.5
Old 05-09-2006 | 01:39 AM
snobird's Avatar
what supercharger will fit the 2.4 ss automatic
Old 05-09-2006 | 03:36 AM
NJHK's Avatar
I doubt they would make it for the automatic because they didn't make one for the J-bodies with Automatics. There are defenite fitment issues and not as much space behind the motor.
Old 05-09-2006 | 03:37 AM
NJHK's Avatar
Nope. Misconception is that the automatic is weak.
Automatics usually die because of heat, not power. If you have an transmission cooler on for insurance, you should be fine.
Old 05-09-2006 | 03:38 AM
NJHK's Avatar
Everything has it's limatations but I think the automatic can handle more than you're probably going to put out.
Brian MP5T's Avatar
The Stock tranny will limit your Torque at the input shaft unless you don't care about reliability..
Old 05-09-2006 | 03:42 AM
NJHK's Avatar
Acutally, it's the opposite.
Manuals would fall out of boost between shifts...why? Remember, they have to release from the gas to press the clutch, then press the gas. Releasing the gas stops exhaust flow and putting down power and drops boost pressure momentarily.
Automatic transmissions if held at full throttle will stay at that PSI straight through. So if you're running 7 PSI, you'll be running 7 PSI from start to finish. Also, automatics can build boost off the line, so that's another advantage.
Don't believe everything that GM says. If you haven't learned by now, GM plays it safe when it comes to power. There have been plenty of people with the 4T40E (granted, not a 4T45E but pretty identical) and are running way over 200 WHP and running strong daily. I myself am aiming for that as well....and will reach it soon.
Old 05-09-2006 | 03:44 AM
NJHK's Avatar
The same roots supercharger that's on the 2.0 Cobalt/Redline.
Old 05-09-2006 | 03:48 AM
Brian MP5T's Avatar
Autos are definately more consistant at the 1/4 but then normally alot more of the power is lost between the crank and the wheels when compared to a MTX..
Old 05-09-2006 | 03:50 AM
NJHK's Avatar
True.
Old 05-09-2006 | 03:56 AM
snobird's Avatar
ok so turbo will fit nicely and work with the auto thats good news just install a tranny cooler and good to go but The Stock tranny will limit your Torque at the input shaft unless you don't care about reliability.. what exctually dose that mean
Old 05-09-2006 | 05:24 AM
Brian MP5T's Avatar
Every Stock Tranny is designed for and only for up to a designed torque load on the input shaft.
The torque usually matches the stock motor torque of the car that it is installed in..
Adding toruqe beyond it's design will reduce the life of the torque converter..
It must be built and watched like a hawk
Old 05-09-2006 | 05:35 AM
snobird's Avatar
but i could upgrade it to be fine correct
Old 05-09-2006 | 06:43 AM
Brian MP5T's Avatar
It would cost alot more than the kit..
A Friend of mine was going to turbo his automatic protege...
After finding out how much it was going to cost to rebuild the ATX so that it would hold up to 12 Psi... He decided to swap the tranny for a MTX because it was going to cost 1/3 less..
We did it in my driveway in a weekend for less than $1000.00
Old 05-09-2006 | 07:50 AM
avro206's Avatar
THe GM Supercharger (2.4L Twincam one) was made specifically for automatics.
Old 05-09-2006 | 03:14 PM
snobird's Avatar
im thnking ill just run 7 psi of boost then or a little less
Old 05-09-2006 | 03:17 PM
Brian MP5T's Avatar
Make sure the wastegate on the kit you buy is set to open that low then, you can inly go up with a boost controller...
Quick Reply: turbo auto question
