Two step launch control
My gf is getting me the n2mb wot box for my birthday I kno if u just wire it for it to only cut spark it'll shoot flames and raw fuel will help spool the turbo my only question is is this bad for anything ?
None ?
None ?
make sure you have a solid connection on all your wiring. its just a pedal position code. even though it wouldnt be the first time i have seen a pedal go bad in these cars
and guess what .. getting a 2 step isn't going to help you get 12s if you cant get 12s on 12 psi... you can't drive .. sorry it's t he truth and a 2 step is just going to make that problem worse .. learn how to drive or get some better tires. you should be at 300 or+ whp .. you **** thats good for mid to low 12s worry about getting the power to the ground before you worry about things to make you launch harder ..
Launch controll will help with my 60ft's when I run slicks and I did datalog alot atleast 2-3 a day for 3 weeks And nothing changed ge just said he didn't see and issues I'm not gettin talkin **** about the guy just sayin the car dosnt run as good as it should it runs crazy rich and does some other weird stuff I'd also like to mess with the exhaust cam phasing like on the lnf's but he didn't wanna do it
and as far as running crazy rich i find that weird he didn't fix that.. all his tunes start out that way.. but he fixes them as you go
