UPDATED 2.4L Performance Modification List
Old 05-17-2009 | 01:13 AM
elecblue06's Avatar
Originally Posted by riko540
I was waiting for you to post cause I couldn't remember the who made the procharger kit lol. Its been added and I moved trifecta and I think I'll rename it also, so not to confuse people.
seriously though whatever balt wants to step forward if they're closeish to me i'll ride out and install everything with them as well as be able to trifecta tune them it would be a small fee obviously but SMP and i are looking to get everything solidified for the balt as well
Old 05-17-2009 | 03:11 AM
slobalt08's Avatar
ZZ Performance Throttlebody adapter plate >>
Has anyone done a LSJ TB swap? Is it worth it? Is there really no tuning required just direct bolt on? If have stock exhaust does doing this swap defeat the purpose? Like don't really see any gains cause of stock exhaust.
Old 05-17-2009 | 09:07 AM
riko540's Avatar
Originally Posted by wesg631
jet also has a mass airflow sensor and a control module
Hmm what should I put that under?
Originally Posted by ssbalt06
also vulcan has pretty dope intake manifolds
Added it, I was crusin around on thier sight and I came across their turbo kit but it doesn't say which engine its for could you guys give me a hand here. http://www.vulcanturbo.com/GMTurboKits.html
Originally Posted by glen229
aem f/ic for tuning for sure
Added it
I'd help but I'm not looking for a procharged setup right now.
ZZP saw gains of 5-7 HP I'm not sure if they were using the stock exhaust when they tested it though.
Old 05-17-2009 | 11:18 AM
wesg631's Avatar
i would put the jet stuff by itself im not even sure if it actually sees any gains i was just putting up for anyone who might be wannting it
Old 05-17-2009 | 11:37 AM
riko540's Avatar
I'll see what I can do.
On another note what do you guys think about adding sound clips for each exhaust in the exhaust section? I want to try to eliminate the "what does _____ exhaust sound like" threads.
Old 05-17-2009 | 01:02 PM
slobalt08's Avatar
That would be a great idea. Also try to link pictures to each item if possible would help too!
Old 05-17-2009 | 01:48 PM
wesg631's Avatar
Great idea about sounds and pictures are great too
Old 05-17-2009 | 03:40 PM
riko540's Avatar
I think I'll give it a go, I might have to go with video clips cause they are easier to come by and I'll cover more of the exhausts that way.
Old 05-17-2009 | 09:51 PM
Shibito's Avatar
Want my vid of my dual Megan Mufflers?
Old 05-17-2009 | 10:11 PM
riko540's Avatar
Sure I can use it
Old 05-18-2009 | 02:14 PM
  #36
Shibito's Avatar
Here ya go, to link it.
http://i249.photobucket.com/albums/g...W/SDC10303.jpg
Old 05-18-2009 | 03:12 PM
  #37
elecblue06's Avatar
http://s200.photobucket.com/albums/a...d430/?newest=1 take whateve rpics and vid you want.. I have exhaust clips in there as well as pics for boost and vidz as well
Old 05-18-2009 | 04:22 PM
  #38
riko540's Avatar
Thanks guys
Old 05-18-2009 | 04:26 PM
  #39
Shibito's Avatar
no problem
Old 05-18-2009 | 08:55 PM
  #40
pat_07ss's Avatar
LSJ Throttle body with ZZP'S Adapter Plate
i just installed mine today
all you need is a relearn for your idle (unplug your batt)
Old 05-23-2009 | 05:27 AM
  #41
rtullos808's Avatar
Perfect
Riko, perfect post, list, everything. Im not a post basher but mentioning Limited Slip Differentials for both auto and manual would make an already perfect post STANDARD.
We dont need a Chilton's, Riko's is way better. Thanks to your new updated list. What need is there to look at any other post. Plus, you don't have to weed through 50% of the immature and just plain ignorant posts. Kudos.
Old 05-23-2009 | 06:12 AM
  #42
slobalt08's Avatar
Quick quesh, will my gmpp intake still fit on a LSJ TB? Can anyone confirm this?
Did it make any noticeable difference?
Old 05-23-2009 | 10:51 AM
  #43
riko540's Avatar
I am really not sure but I don't think so seeing how the TB is bigger but thats just a guess.
Old 05-30-2009 | 04:16 PM
  #44
riko540's Avatar
bump any more anymore exhaust vids to add?
Old 07-04-2009 | 09:38 PM
  #45
riko540's Avatar
Updated
Old 07-08-2009 | 12:25 PM
  #46
rockstar014's Avatar
what about 60# injectors
Old 07-08-2009 | 01:09 PM
  #47
Dunkinuts's Avatar
I will have vibrant and ark DT-S here shortly.
Old 07-08-2009 | 05:28 PM
  #48
riko540's Avatar
got a link
Old 07-15-2009 | 08:16 AM
  #49
Dunkinuts's Avatar
http://www.youtube.com/watch?v=_VRKD4DlVjE
Vibrant header/downpipe with Ark dt-s catback
Old 07-15-2009 | 03:44 PM
  #50
sweet this list is looking good riko
Quick Reply: UPDATED 2.4L Performance Modification List
