Valvesprings and Boost
Old 02-14-2010 | 03:19 PM
redssna's Avatar
I would never rev over 7k on a boosted application anyway. No need. I have a 7k limiter but typically shift at 6,500. And since when does compression ratio have anything to do with valve float?
Old 02-14-2010 | 03:21 PM
glen229's Avatar
it doesnt, and redssna i totally agree
Old 02-14-2010 | 04:00 PM
slowswap's Avatar
So what's your opinion glen? Your pretty knowledgeable about these motors, 18 psi at 7000 fairly safe?
Old 02-14-2010 | 04:05 PM
glen229's Avatar
fairly safe, no lol
its all in the tune, 18psi is alot of boost, but in retrospec it all depends on how big of a turbo you go with, or if your supercharged etc etc
but 18psi on a 2.4 motor is kinda vauge
Old 02-14-2010 | 04:10 PM
slowswap's Avatar
Originally Posted by glen229
fairly safe, no lol
I'm only talking about valve float, not about boost.
Old 02-14-2010 | 04:11 PM
glen229's Avatar
well i got thrown off because you said 18psi, but 7000 isnt all that extreme, i run 7100 on the street tune
Old 02-14-2010 | 04:12 PM
slowswap's Avatar
And you have no valve float?
Old 02-14-2010 | 04:13 PM
glen229's Avatar
nope, ill be getting the supertech springs as well as some other goodies next year though
Old 02-14-2010 | 04:14 PM
slowswap's Avatar
Some good info.
Old 02-14-2010 | 04:16 PM
redssna's Avatar
Yea the application we're looking at here would be for my 2.4. I'm going to be doing a supercharger build in a couple months and would like to run a 2.75 pulley. But we were concerned with the ~17-18psi that would result from that and if the valves would start to experience float. The car would never be revved above 7,000 rpm though.
Old 02-14-2010 | 04:19 PM
  #36
Matt M's Avatar
We were unable to run 15psi much past 7000 RPM. After a few trips to the track, the springs also seemed to get worse quickly. Eventually, power was falling off at 6500 RPM at 15psi and there was audible misfiring a little below 7k. When we swapped the springs out, we tested the old ones and found some in the 45-48lb range even though I believe they are supposed to be 60lb. With the new springs in, HP kept climbing to 7500+ RPM at 15psi and we had no problems at 17psi and 7900 RPMs.
As far as LNFs, the cam lobe shapes may be completely different. Either way, not too many people are revving them past 7k. They also have less miles on them in most cases.
Old 02-14-2010 | 04:21 PM
  #37
slowswap's Avatar
We're not trying to run past 7000 at all. Any thoughts to why the LNF can run higher boost with similar cams and the same valve springs??
Old 02-14-2010 | 04:42 PM
  #38
elecblue06's Avatar
i don't know why i didn't think of / mention the RPM issue.. considering thats a key factor.. when i up the boost i'll be looking at a 7k redline and about 17 psi.. i'll find out how it is.. if there is an issue i'll pick up the zzp valve springs or the patriot 72lbs ones
Old 02-14-2010 | 08:07 PM
  #39
Matt M's Avatar
You answered your own question. Not revving as high is the biggest factor.
I want to add that even when you can't tell that there is valve float/bounce, you may still be losing power. Many LNF power bands will carry out to higher RPMs with stronger valve springs.
Old 02-14-2010 | 08:08 PM
  #40
slowswap's Avatar
Thank you sir!
Old 02-14-2010 | 08:31 PM
  #41
elite_Cyborg's Avatar
what exactly does valve float look like on the tach?
Old 02-14-2010 | 09:08 PM
  #42
elecblue06's Avatar
Thank you sir!
you ignored the rest of it.. where he says with stronger valve springs you can extend the power band
Old 02-14-2010 | 09:11 PM
  #43
slowswap's Avatar
I'm only asking with boost up to 7,000 RPM. I'm not talking about a higher redline then 7,000.
Old 02-14-2010 | 09:41 PM
  #44
elecblue06's Avatar
lnfs drop off at like 5800.. so if it extends the powerband till 7200 then that includes boosting up to 7k..
Old 02-14-2010 | 10:34 PM
  #45
HunterKiller89's Avatar
Originally Posted by mmcgee123
U also need to consider compression ratio at 15 psi with 10.6-1 comp
10.4:1 vs 9.2:1 CR, and while i dont know if the cams are the same between the LE5 and LNF (likely just timed different or just minor changes), but things like ramp rate will also be a factor. Also, that does the LNF redline at, and what does the LE5 redline at?
Symptoms of valve float are really just a loss of power assuming its not floating enough to cause the valves to hit the piston.
Old 02-14-2010 | 10:40 PM
  #46
slowswap's Avatar
I guess it is worth noting RPM. Maybe an over looked detail of LNF vs LE5 valve float debate. LE5 is 6750 from factory and the LNF is 6300. 6300 might be ideal redline for higher boost numbers.
Wonder what RPM tuned guys are pushing?
turbochargedss2012
09-20-2023 12:17 PM
Sl0wbaltSS
11-21-2018 11:11 PM
01-12-2016 12:01 AM
tomj77
10-04-2015 11:39 AM
nathan112i
09-30-2015 07:12 PM
Quick Reply: Valvesprings and Boost
