Valvesprings and Boost
I would never rev over 7k on a boosted application anyway. No need. I have a 7k limiter but typically shift at 6,500. And since when does compression ratio have anything to do with valve float?
fairly safe, no lol
its all in the tune, 18psi is alot of boost, but in retrospec it all depends on how big of a turbo you go with, or if your supercharged etc etc
but 18psi on a 2.4 motor is kinda vauge
Yea the application we're looking at here would be for my 2.4. I'm going to be doing a supercharger build in a couple months and would like to run a 2.75 pulley. But we were concerned with the ~17-18psi that would result from that and if the valves would start to experience float. The car would never be revved above 7,000 rpm though.
#36
As far as LNFs, the cam lobe shapes may be completely different. Either way, not too many people are revving them past 7k. They also have less miles on them in most cases.
#37
We were unable to run 15psi much past 7000 RPM. After a few trips to the track, the springs also seemed to get worse quickly. Eventually, power was falling off at 6500 RPM at 15psi and there was audible misfiring a little below 7k. When we swapped the springs out, we tested the old ones and found some in the 45-48lb range even though I believe they are supposed to be 60lb. With the new springs in, HP kept climbing to 7500+ RPM at 15psi and we had no problems at 17psi and 7900 RPMs.
#38
i don't know why i didn't think of / mention the RPM issue.. considering thats a key factor.. when i up the boost i'll be looking at a 7k redline and about 17 psi.. i'll find out how it is.. if there is an issue i'll pick up the zzp valve springs or the patriot 72lbs ones
#39
I want to add that even when you can't tell that there is valve float/bounce, you may still be losing power. Many LNF power bands will carry out to higher RPMs with stronger valve springs.
#43
#44
#45
10.4:1 vs 9.2:1 CR, and while i dont know if the cams are the same between the LE5 and LNF (likely just timed different or just minor changes), but things like ramp rate will also be a factor. Also, that does the LNF redline at, and what does the LE5 redline at?
Symptoms of valve float are really just a loss of power assuming its not floating enough to cause the valves to hit the piston.
#46
I guess it is worth noting RPM. Maybe an over looked detail of LNF vs LE5 valve float debate. LE5 is 6750 from factory and the LNF is 6300. 6300 might be ideal redline for higher boost numbers.
Wonder what RPM tuned guys are pushing?
