VVT Tuning?
#51
Originally Posted by pulley police
Now, I dont know the ins and outs of these ECUS specifically, but I DOUBT that they are using one "midpoint" master table and only multi level fuel trims to correct the AFR to get away with not having a 5-D MAF table....but they could be...it is definately simpler.
nope, nevermind. I'm wrong: http://www.asashop.org/autoinc/jan2005/techtips.htm
#52
MAF doesnt work the same as the VE. VE is MAP based and has, as over-stated and under-understood, 5d-blahblahblahblahblah. Maf of course only has one axis, manifold hz. The only "odd" part of our Maf is the use of high and low tables.
Not sure what you mean by "midpoint", but the ECU uses both MAP and MAF to calculate AFR, and ranges for learn... you dont need a 5d MAF if MAP is doing that calculation for you.
#53
Going to the track tomorrow afternoon. illmatic3s and I have some tunes I want to try out.
I'm going to start out with stock tune. w/ my full bolt ons.
Last summer my car ran a 15.99 stock @ 84mph
THIS IS AUTOMATIC
This year I have wider tires;
InjenCAI, Header, DP, HI-FLO Cat, Borla Exhaust and our tunes. I'm tearing out spare tire and all my tools are coming out for tomorrow, i should be around 1/4 tank of gas by the time i get to the track. It will be 65 degrees Sunny tomorrow is what is forecasted.
I'll log the runs and hopefully rig up my camera to record in car.
Wish me luck... if Im still in the 15s i'm going to be very upset. I hope to crack into high 14s.
THIS IS AUTOMATIC
#54
THIS IS AUTOMATIC
InjenCAI, Header, DP, HI-FLO Cat, Borla Exhaust and our tunes. I'm tearing out the back seat, spare tire, and all my tools are coming out for tomorrow, i should be around 1/4 tank of gas by the time i get to the track. It will be 65 degrees Sunny tomorrow is what is forecasted.
THIS IS AUTOMATIC
#56
Just got home form Pittsburgh Raceway park
track conditions were not so good. Strong headwind blowing at me, very strong gusts.
But an increase over last year with the stock setup
reaction.63 best:.0753
60ft 2.30 best: 2.29
330ft 6.49 best: 6.49
1/8 9.92 best: 9.92
1/8mph 72.25 best:72.25
1000ET 12.95 best:12.95
1/4 15.54 best: 15.54
1/4mph 87.74
My tunes I could not get the car to shift @ WOT, I tried 3 different ones... this was my 1st run and I hit rev limit twice on this run. 1st to 2nd then 2nd to 3rd. I feel that once this gets taken care of I should be getting close to the 15.0 second mark, as these rev limited bounces really hurt me at the end. I also maxed IDC once again.
Looks like illmatic3s and I have some more homework to do.
1/8 9.92 best: 9.92
1/4mph 87.74
#63
If you guys want to sift thru my clubs video from this past trip the drag strip my cobalt's top 2 runs are in the video, and my good friends cobalt ss/sc stg 2 has a few runs also along witha few other friends cars.
15.59 and a 15.54 .... going for 15.1 next time
http://youtube.com/watch?v=w9U2-l2guCE
