Well, Christine's at the dealer...
Old 06-08-2010 | 03:41 PM
joshc.'s Avatar
I've seen bad TPS signal cause the same issue, as well as fuel trims.
Also I would find another dealership cause there driveabilty tech is a sorry excuse for a technician. Driveabilty problems aren't always cut and dry.
Old 06-08-2010 | 03:48 PM
rossshady120's Avatar
i know vince tuned my tranny and left the gm torque management on i mean it doesnt feel like its shifting clean at all but thats what u get when u s/c a n/a car. What do you mean you cant replace the tranny every 8 months this happened before?
Old 06-08-2010 | 06:36 PM
Illini_06SS's Avatar
She's back home. She'll be parked in the garage until I can get all of the absolutely necessary parts I still need (LE5 IM, TB, tensioner pulley) and then I'm going to convert her back to N/A... I may start pulling parts off before then, but I want to make sure I at least have line of sight to getting the parts... This'll also give me some time to bank a bit more cash to pay for the repair. If all goes well, I'll have her naturally aspirated and have sold the kit before paying for the repair and it won't cost me much out of pocket...
Old 06-08-2010 | 07:10 PM
_UnLiMiTeD_'s Avatar
.... so your going back to n/a even though theres a good possibility its just a tuning issue? Now im confused, im fairly confident your tranny is fine, your not putting that much power through it. ZZP made a **** ton of passes with twice as much torque through their stock tranny before it finally gave out and all it seen was WOT driving.
Your choice, but what a waste of time to go S/C just to freak out and sell it off at the sign of an issue. Thats the risk of modding any car, you push it, something might give, in your case, it could be completely fine and just need a tranny tune and your on your way.
No offense but you shouldn't be modding cars if thats what you do when theres an issue. You dont even know what your issue is and your already going to go back to stock.
Old 06-09-2010 | 12:41 PM
idk shouldnt i let me old tranny go before i go drop 3k on a new one? i would take out a loan i mean this is the life we live modding N/A balts with auto tranny with OD. I pray to god i wont be the only 2.4 tvs with a automatic lsd race tranny
4T40-E / 4T45-E GENERAL MOTORS FRONT WHEEL DRIVE
Cavalier, Malibu, Cutlass, Alero, Grand Am, Sunfire
Valve bodies are custom calibrated to provide firm, efficient shifts.
Modified pressure regulation system to furnish precise line pressure increase as needed with open throttle conditions.
Redesigned converter clutch apply circuit to yield greater holding capacity under high horsepower use.
New Solenoids installed
Modified pressure control solenoid installed (4T65E)
Additional Clutches Installed
Hi-Energy Friction Material Installed
Modified pump to increase volume and enhance fluid flow throughout the unit.
Heat treated pump driveshaft to prevent spline stripping
Heat treated apply sleeve to prevent breakage
Modified aftermarket front sun gear to prevent the pitting and galling often associated with the OEM part.
Heat treated final drive sun gear to prevent the metal fatigue associated with the OEM part.
New Torrington Bearing set installed to reduce frictional losses and prevent component failure
High strength drive chains utilized to prevent stretch and skipping teeth.
Limited Slip Differential available (optional)
4T40-E and 4T45-E: $2975
Old 06-10-2010 | 09:23 AM
The issue is that it is not just me under my roof. I'm married and, while my wife is very understanding in the build/modify stage, she's apparently not so understanding in the "Oh ****, my **** just blew up and now I've gotta repair it" stage.
Sometimes it's a better choice to accept defeat, appease the giver of the sexeh time, and keep the peace...
That said, I'll be more competitive in ST than I would be in SMF, anyways
Old 06-10-2010 | 11:45 AM
yes but if its literally a tuning issue, why the hell would you tear it down for that?
Old 06-10-2010 | 11:46 AM
383_Stroker's Avatar
Old 06-10-2010 | 11:47 AM
Because I've taken it and gotten 2nd and 3rd opinions that it is in fact due to slipping in the transmission, despite the absence of a CEL. We plan on finishing our basement this summer so having the cash from selling the kit will be a huge help once we start to furnish all the new living space.
Originally Posted by 383_Stroker
Anyone who is married would agree with me!
Old 06-10-2010 | 11:14 PM
this **** is really scaring the **** out of me i may just go ahead and get the race tranny and keep it in the living room just in case
Old 06-11-2010 | 12:45 AM
  #36
i wish i would have gotten such a big allowance from my parents like you do, i could keep a few spare motors laying around..
Old 06-11-2010 | 12:53 AM
  #37
no you should have got a IRA or a 401k
Old 06-11-2010 | 01:07 AM
  #38
i dont think you would have one there ross, your like 16
Old 06-11-2010 | 01:19 AM
  #39
dude everyone knows i'm stright outta 89 broski
Old 06-11-2010 | 01:24 AM
  #40
like i said, 16
Old 06-30-2010 | 10:30 AM
  #41
Figure I'd give an update. Took it to another dealer in the area (much bigger than the local one, it's in Peoria). Took the transmission guy (who apparently replaces 4T45E's like crazy in Malibu's and Cobalts) for a ride he said it could be the torque converter or a problem with the valve body, but he couldn't be sure, either.
I'm heading out for vacation so I just left it with them and told them to figure it out Hopefully when I get back into town she'll be back up and running and ready for some fun in the turns.
Old 07-01-2010 | 02:33 PM
  #42
good to hear!!!!!
josh2j11
03-28-2013 06:28 PM
Quick Reply: Well, Christine's at the dealer...
