what to look for when picking exhaust?
Old 12-13-2011 | 01:55 PM
NICOMAN's Avatar
ok..pretty much every exhaust that i find keeps saying "only fits sc"..or.."does not fit non sc or non turbo models"..and doesnt the sc and the na have the same 2.5 inch pipe? y wouldnt i be able to fit ? i really like the sound of the loudmouth and its affordable ..but again says it wont fit the na? ..i want something mean and loud..any suggestions on what to look for ?
Old 12-13-2011 | 07:46 PM
Mindrot's Avatar
I was under the impression that all "SC" exhaust systems will fit? I could have sworn that the only "fitment" issue falls on if its an auto or not. The auto clocks the motor forward towards the bumper a little bit which can cause fitment issues near the header/dp. Vibrant is a prime example of this. My headers rub without a solid upper mount.
Edit: I'm an Automatic
Old 12-14-2011 | 01:10 PM
NICOMAN's Avatar
yeah im stick soo i should be fine right?
Old 12-14-2011 | 01:21 PM
TommyP's Avatar
AWD > FWD
Any of the cat backs that fit the 2.2 or sc will fit the 2.4
Old 12-14-2011 | 01:35 PM
NICOMAN's Avatar
what u think of this system..ive heard it b4 and it sounds amazing..
31790 2006 SLP Loudmouth II cat-back for 2005-07 Cobalt SS, SLP 31790, SLP Exhaust System
Old 12-14-2011 | 01:37 PM
NICOMAN's Avatar
but again is says clearly in it that it wont fit non sc or tc cars..but than it says its a 2.5 ..u think itll fit?
Old 12-14-2011 | 04:43 PM
TurboTechRacing's Avatar
This is true, solid mounts help prevent rocking of the engine, which helps reduce exhaust hitting, and flex joints breaking...
OP: We have many exhaust systems on www.TurboTechRacing.com that fit your application, PM us with any questions
Old 12-14-2011 | 08:23 PM
-TurboSS-'s Avatar
Mandrel exhaust systems/trubendz will build you anything you want, and is very reasonable depending on material used and size, etc.
Old 12-14-2011 | 08:31 PM
Mindrot's Avatar
I wish we could get information like this stickied in our section. Theres little to nothing really done on the LE5 section here and its sad
Old 12-14-2011 | 11:19 PM
noorj's Avatar
Any cat-back that says it will fit the ss/sc will fit on a 2.4. The only thing you want to be careful of is a catback designed for the 2.2, some will be too short but others will work. Just look for a good ss/sc catback. I love my magnaflow btw
Supercharged06SS
12-11-2022 04:47 PM
05-28-2022 03:47 AM
01-12-2016 12:01 AM
hacadacalopolis
10-28-2015 06:09 PM
RaginChopsuey
10-27-2015 01:27 PM
Quick Reply: what to look for when picking exhaust?
