whats better short ram or full ?
Old 04-04-2008 | 05:00 PM
  #76
FASTL61's Avatar
ya ive had mine on for a long time now and never had any problems...cleaning the filter itself is not hard at either!i like it plus it sounds good with the exhaust as well
Old 04-04-2008 | 05:06 PM
  #77
Zdeuce4's Avatar
guess ill be oiling it then.. eff me.
Old 04-04-2008 | 05:17 PM
  #78
FASTL61's Avatar
ya if you run em dry then they can crack and get holes in them easier.keep em wet..lol
Old 04-05-2008 | 12:36 PM
  #79
Evil C's Avatar
Ok let me rephrase what i meant by it will never look red again. Any time ive used the cleaning kit to clean the filter and oiled it to the point it looked red again even after letting a filter hang over night to drip off the excess (mind you i own like 6 or 7 of these thing from my previous cars) they would still leave puddles of red oil in the air cleaner box.
Old 04-05-2008 | 12:45 PM
  #80
Zdeuce4's Avatar
k&n ftw.. my gas mileage went up 2 mpg and ive gotten on it a bit more.. i thnk with a tad more conservative driving ill get about 30mpg
Old 04-05-2008 | 02:49 PM
  #81
Ducky22287's Avatar
Def go for a CAI, I just got an injen from TTR and just need to install it.
Old 04-05-2008 | 02:54 PM
  #82
deleon_soldier's Avatar
A CAI is better than the short ram, but just be careful with water puddles!!
Old 04-05-2008 | 05:33 PM
  #83
eber's Avatar
I can't believe this is a discussion. Physics is the basic principle. Dense air = better compression=more power. Therefore the cai takes the coldest air...outside of the engine bay and funnels it into the intake. IE) intercoolers, heat exchangers, ram intakes, funnels and so on. Cold air makes more power! Who gives a **** what it looks like as long as you go faster
Old 04-05-2008 | 05:37 PM
  #84
M-Dub's Avatar
Just a word of advice... with the K&N oiled filters....
When you clean them... let them dry... and oil to a light pinkish color! No more!!!
Old 04-05-2008 | 06:13 PM
  #85
Evil C's Avatar
True enough for the most part. But SRI gives better throttle responce and The GMPP CAI which is still a SRI and a CAI Kinda is the best of both worlds because its ducted to feed from the same area as every other CAI on the market (just below the headlight). It seals up to the hood if you want a hood scoop later on and the filter is not a PITA to change. Granted the filter that comes with the GMPP CAI is garbage and should be changed asap.
Old 04-05-2008 | 10:29 PM
  #86
Austyn_Balt's Avatar
Yah, if you had an open tube. It depends on the manufacturer and how they set up there designs. To many bends in the pipe can cause bad air flow, a poorly made air filter (to dense not allowing enough air threw, or not dense enough and letting water/other debris through.) I had the fujita on my 2.4L saturn and it was shitty. It sounded alot better but performance increase were zero and gas milage was even worse because you cant resist opening it up to here the sound. It also re-used the stock air box which make it less effective.
Old 04-06-2008 | 12:07 AM
  #87
FASTL61's Avatar
ill say it again no such thing as cold air intake in arizone unless your up north which im not
Sl0wbaltSS
11-21-2018 11:11 PM
brandon04
10-21-2015 07:04 AM
OrangeCoba
10-01-2015 10:00 PM
SSLOW06
10-01-2015 07:21 PM
dieGone
10-01-2015 06:27 PM
Quick Reply: whats better short ram or full ?
