Whats needed: 8k
my e-dick is bigger btw then yours but....
I don't even know if 2.4 internals are available to do what your looking for. I know there is availablity on the 2.0 & 2.2 but 2.4 is tricky plus your dealing with a custom VVT camshaft... some parts are interchangeable on the 2.0 - 2.2 but I don't think the 2.4 has anything out yet unless you go custom. Talk with G5Delta. He had a custom cam and retainers/other internal goodies done but had difficulties in the past getting it done due to stupidity from other people and lack of information given on his setup as well.
on my Patriot Stage 2 head, the springs and retainers were the only thing that was replaced - everything else internally is still stock and the head is supposed to be bulletproof to 8K.
neutral balance shafts may benefit you but I don't believe they are full required.
but as already said, basically cams to make it worth it and springs/retainers.
