Who would want a tune that...
I need to get some core pcm's before I can send them to you guys. Price will be up later tonight. you tell me your mods and I will configure your pcm accordingly. some things that I can do
raise rev limit
raise speed limit
better gas mileage
remove tq management
change shift speeds and firmness of auto trans
change fan temps
change timing and fueling depending upon mods
delete codes
theres alot more I can change to.
raise rev limit
raise speed limit
better gas mileage
change fan temps
delete codes
cold air intake, slightly bored out LSJ header/downpipe, 2.5 inch exhaust. id like a higher rev limit, speed limit, gas mileage , tq management sounds nice (what is it?), fans running a bit faster than normal and always running, timing/AFR of course, no codes here, and im interested in what else you can do
thanks
thanks
thanks
thanks
08 support isn't out yet.
Just email me your stock or modified tune file and I will make the changes and send it back to you.
admin@ottperformance.com
Hey man dont take this the wrong way, but who are ya and how long have you been tunning cars, what experence do you have doing this, seems now a days anyone can just grab HPT and claim then can make your car a vette.....
#36
Are the PCM's different thru out the different years and different engines? ie: 2006 vs. 2007 2.4L OR 2.2L vs. 2.4L? I'm assuming the engines are different PCM's but for all I know they could be the same.
#37
I know the 2.2 is different. The 2.4 should have the same pcm from 2005 and up though
#38
Original Hayden Fanatic
Him and his partner (lsjwannabe) are among some of the most respected and knowledgeable members on the forum IMO, I would let either of them tune my car with complete faith.
#41
#48
