Why wont it work? Guru's only, 2.4L Supercharger for cavs
Old 07-17-2007 | 09:14 PM
UpOnGaMe's Avatar
http://tunersource.gmblogs.com/Acces...-supercharger/
Why wont it work? specificly, ok so tunning was a problem right? well Witt cracked the code so did Hanh? What else is a major factor of why it wont work?
Old 07-17-2007 | 10:04 PM
mike25's Avatar
well thats a setup for a twin cam engine...ours it a dual overhead...totally different setup on that...your argument might be more plausible if you put the 2.2 s/c up there
Old 07-18-2007 | 12:45 AM
TCarter's Avatar
There was a cat in the 2.2 section that put a supercharger on his, if you could find out exactly what he did..im sure you can put it on your 2.4.
RaginChopsuey
10-27-2015 01:27 PM
brandon04
10-21-2015 07:04 AM
dennis69
10-20-2015 04:49 PM
SSLOW06
10-01-2015 07:21 PM
09-26-2015 06:44 PM
Quick Reply: Why wont it work? Guru's only, 2.4L Supercharger for cavs
