will a 2.4 fit in the 2.2 bay
Old 01-19-2011 | 08:49 AM
06_cobalt_ls_turbo's Avatar
Lightbulb will a 2.4 fit in the 2.2 bay
i guess what im trying to ask is i have a chevy cobalt ls 2.2 turbo and i blew a rod due to a bad oil leak and i need an new motor and i was looking at the 2.4 motor caz they have 170hp stock and i was wondering if it would fit in my cobalt ls 2.2 any one know or know of any site that i could get this info from
Old 01-19-2011 | 08:53 AM
dandaman15's Avatar
Yes it will physically fit but with the way connectors for sensors are it may not just plug right up. Your better off getting a 2.2 and building it. If you want a 2.4 take your old block if its fine and stroke that to 2.4.
Old 01-19-2011 | 09:09 AM
no my old block is f***ed i blew a rod trough the motor and it was built i have a lil bit over 300hp to the wheels i had a turbo exhaust tune throtalbody built the top end a lil and that thing was a beast i just wanted the 2.4 caz it comes stock with 170hp rather than 145 so thats a big diff after i put all my stuff on it from my 2.2 such as turbo injectors tune exhaust all that good stuff just trying to get more bang for my buck caz the motors are really close in price
Old 01-19-2011 | 09:11 AM
alleycat58's Avatar
If you could pull it off, you'd be the first to do it. Yes it fits, but you'll need a lot of electrical work, new sensors, different computer, etc to make it happen. Not worth it for 30hp.
Old 01-19-2011 | 09:26 AM
j27-2's Avatar
in order to make it work you will need to put your stock head on the le5 block. the le5 has a 58x reluctor wheel on the crank that bolts on witch is shared between 07+ l61, le5 , lap, lsj, lnf. your 06 l61 has a cast 7x reluctor wheel on the crank. so you will have to go with a stand alone for tuning unless you can find a way to switch to the e37 ecu (07+ l61)
Old 01-19-2011 | 09:27 AM
damn thats what i was afraid of is replasing all the bullshit i will probably just got with the 2.2 then and just put on all my old stuff on the new motor everythiong thats goin on new motor : godspeed turbo, dc exhaust zzp injectors trifecta tune top end build garrett downpipe coldair intake on turbo head routed under my car new mads going in the new 2.2 all of the above and meth injection nos spray on intercooler new rods pistons hopefully twin turboes beasyest setup for the balt ever!!!!!! well atleast i think soo my goal with the balt is 450hp++++ with major builds and some nice ass slicks
Old 01-19-2011 | 09:30 AM
i guess i was just hoping for some plugandplay but i get non of that out of the 2.4 build so forget it hahaha
Old 01-19-2011 | 09:34 AM
so does any one know what year of a 2.2 i have to put in or does it matter caz i have the 06 ls 2.2 do i have to put in the 06 or can i go newer 2.2
j27-2's Avatar
i just checked the specks you could put your 06 l61 crank in the le5 to work around the reluctor wheel but the displacement will be 2.2 not 2.4 anyone please correct me if I'm wrong i dont have the rod dimensions just the crank.
Old 01-24-2011 | 12:02 AM
06SS ALL DAY's Avatar
if its not already too late... do this and be happy... Cobalt & Ion ---> ZZ Performance
Old 01-24-2011 | 07:33 PM
LS6Rally's Avatar
300 Horse? got any pics of hte dyno sheet or track times?
Zdeuce4's Avatar
waste of time. 2.2s have bigger aftermarket
Old 01-24-2011 | 07:37 PM
royce777's Avatar
just put the 2.0 motor in it LNF
Old 01-25-2011 | 12:43 PM
slobalt08's Avatar
^^ 2.4 has higher compression boost doesnt like that
Old 01-25-2011 | 12:47 PM
Zdeuce4's Avatar
2.4 loves boost. ask me how i know
Old 01-25-2011 | 07:59 PM
Shibito's Avatar
2.4's take boost very well. I've seen a few putting down 350-360whp.
Old 01-25-2011 | 08:08 PM
LS6Rally's Avatar
Compression doesnt car about boost, head bolt and Rods do! but the 06=07 2.4s are solid motors
Old 01-26-2011 | 12:10 AM
Zdeuce4's Avatar
just saw ur sig with ur plate fk u! ( i <3 zo6s)
hahaha wish i still had my balt... or... wish i wasnt about to buy an engagement ring for my chick. lol
hacadacalopolis
10-28-2015 06:09 PM
Tupp
09-30-2015 08:18 PM
Dylan Johnson
09-30-2015 08:57 AM
Delta coupe
09-30-2015 08:11 AM
09-26-2015 06:44 PM
Quick Reply: will a 2.4 fit in the 2.2 bay
