winter plans
Ok, so who got their Last Winters plans/projects completed? And what are your this Winters plans?
I am starting my 2.4L SC build this January, hopefully start it the first or second week, just waiting out the holidays to get passed to start it.
2008 2LT Chevy HHR Panel, LE5 2.4 Ecotec VVT Motor, Auto Transmission
Eaton M62 Supercharger
(Collected my own SC "Kit" Parts, mostly came off a 2007 2.0 Chevrolet Cobalt SS, when it had 40,000 miles on it. )
ZZP Modular 3.1 pully Kit
LSJ throttle body
Spark Plugs are NGK 3672(LFR6A-11)
Bad Mab Stainless Steel Header Shorty Header 4-1, 1.71 inch, equal length tubing and a 3 inch collector
ZZP 3 inch to 2.5 inch high flo catted stainless steel downpipe, with extra bung for widband gauge
All pullies to be swapped out to the stock 2.0 6 rib pullies
CXRacing Heat Exchanger
ZZP Dual Pass End Plate on intake manifold
Cobalt Coolant Tank for Option B
ZZP Siemans 60# EV6 Injectors
OEM 2.5"? exhaust system except replaced the oem muffler with a Thrush 17713 Turbo Muffler
Cylinder Head Swap (bought from hhrfreek from his 2.4 SC HHR) has been ported on exhaust side with
ZZP LE5 2.4 Cams
78# Springs, Retainers installed
ARP Ecotec head stud kit
Glow Shift 30 PSI Boost Gauge
Glow Shift Digital Wideband Air/Fuel Gauge
Stock OEM 2.5 MAP Sensor (that was on the 2.0 SC intake manifold of the donor cobalt ss/sc)
Thinking on getting that ZZP Stealth Heat Exchanger, to help cooling.
My build thread can be found here with pics.
https://www.cobaltss.net/forums/2-4l...d-swap-289429/
So, did you get last years winter projects done and whats everyones winter plans/projects for this years Winter?
LSJ throttle body
ZZP LE5 2.4 Cams
Guess I can post the camaro plans...
New front 275/40/17 tires - Done
New front control arms - Picking up this weekend
80lb injectors
Dual 340 intank pumps
317 or 243 heads with upgraded valve springs
Speed incorporated TU2 cam
Ported Ls6 oil pump
Full custom exhaust
Speed density tune by the ecotec tuning guru (P&P tuning)
Maybe a few other goodies.
80lb injectors
Ported Ls6 oil pump
Full custom exhaust
Hopefully I will be installing DW300, piecing together return system using lsj fuel rail, pump rewire kit, 80s, 2.7" pulley for TVS, head studs, level zero balance shaft delete, P&P head, valve springs, and ZZP axles.
Don't know if I'll he the money for built P&P head, minimum of springs and studs
Hey HHR panel man, when you start the build I prolly tell
My boss to suck it and take Friday, Saturday, or Sunday off from work and drive up to give you those parts and pick up your stock head if you would be willing to sell it.
Drive is bout 4 hours, I can prolly make it in 3-3.5 hours
Im rolling 14-15psi on TVS; Never even pulled valve cover yet
from what I have heard, mostly the RPMs that'll get you in trouble and not really the boost
My **** sees 7K at least once a day though
I'm running 8psi on the ZZP stage 2 turbo kit with everything else stock. I don't know how far I can push it. I rarely ever get it close to 7k though haha. But I don't have my KY Stage 3 clutch in yet.. I might see more 7k's here soon haha. My stock clutch slips 3rd-5th in boost. :/
Winter SUCKS! And i'd be Tempted to drive my Panel once installed, I Park my HHR Panel for the Winter because the salt reeks havok on all the polished stainless steel pieces I have.
Still got those parts, thought maybe you sold em locally by now. I'll still take em both.
To be honest, I don't have any plans on selling off my stock OEM Head right now.
But if that changes, i'd give you First dibs on it.
I have kept all on my stock parts from all my mods, so I could swap my Panel back to OEM at any time. Don't plan on ever selling my car, but you never know and putting all back to stock makes for better/easier trade ins at new car dealers.
Have a look at my build thread, I have parts listed and plenty of pics. Link in my Sig line.
I will be doing the install at a buddy of mines Shop. I just redid all his vinyl sign work for him, so the use of his shop for my install was our Trade off. He has 3 Lifts at his shop.
So I won't be doing my install out in my driveway in the cold and snow if there is any.
I have a $1500 budget for 2013, nothing big planned.
BRFS
maybe ID 720s ($500!!! daymn)
Thinking I might do option 2 on zzps brfs, keep fuel rail pressure lower and static until boost then 1:1, between that and the Injector Dynamics 720s I should give myself a gold plated fueling setup. If I dont drop the 5 bills for the injectors I may try the same using my deka 60ies and see how it goes with my IDCs.
I'd like powells Spherical CABS, probably need new ball joint, tonnes of little things that will eat the budget pretty quick.
BRFS
I'd love to have you onboard with my install, since you have already done it before. Was planning on the first week of January, but may Delay it until mid or end of January.
Aiight; Yes I have the parts, figured Id just drive up there. I'm planning on getting a head built up and just swap everything over to minimize the downtime
#36
Plan on finally doing my clutch. It's so bad at this point I can't accelerated more than 1/3 throttle or I get ridiculous slip. I'll probably throw on the ZZP longtubes I bought at that point also. And I was thinking about doing E85 for ***** and gigs, see if it does anything
#37
I will be doing zzp block ,rods, je pistons ported head there cams id 1000's with brfp set up stealth 340 pump zzp retune on e85 not sure if I'm going get get a s259 yet or not we will see what we can get out of the s256 first come next spring
#38
I am waiting for a performance autowerks intercooler and hf downpipe. After spring gets here going to install those, get tuned and finally get some power out of this lame ass LNF. Very likely getting tuned by term, unless I have the patience to learn another pcm.
While its parked I am going to polish some bits under the hood so it looks a little nicer.
Also finally sending Mark some straps for that meth kit
#41
I can't believe you haven't changed it out yet. Sub'd for can't drive up hill because clutch slips. E85 make racecar. You will like the power...and hate the annoyance of looking for e85 stations and seasonal blends.
Hey I had a busy semester! haha but yeah it's getting ridiculous. I think I'll start to daily the bike once spring rolls around anyways but we shall see.
Go catless! the LNF sounds amazing catless
#43
my brother has a 88 iroc z built 350 40 over AM muffl thing is nasty, paid 500 bones for it, dude couldnt get it runnin and all it was is the distributor cap n rod thing and a head gasket to fix knocking. we want to dyno that sheit
