Xxx Issues with Braking System xxX
Old 08-08-2007 | 04:14 PM
wordsthatiwrote's Avatar
I was going off toping on another thread and I decided that I would create a new thread about problems or issues people are having with their braking system. What ever the case may be please use this section to educate ourselves.
I own a 2007 SS/NA and I had to have the dealer resurface my rotors around 10,000 miles. People have been having some problems getting the dealer to take care of them. I obviously had no issues with my dealer because they rock. Now about 4,000 miles later i am having the same issues as i was before. Although the shuddering isnt as extreme as the first time i experienced it, I will still be taking the car in to have it checked when I get them to change my oil.
Old 08-08-2007 | 05:48 PM
06sscobalt's Avatar
i have an 06ss/na with 18k miles i had my dealer replace my rotors once but they said " were only gona do this once if it happends agian we WILL NOT cover it" i had em replaced the first time at 8500 miles and for the past 2k miles i can tell my rotors are messed up and i dont brake hard i dont abuse the car at all the rotors just suck lol
Old 08-08-2007 | 06:53 PM
It would seem that everyone that has had problems has said basically the same thing that you are saying. They are just a horrible set of rotors.
Old 08-08-2007 | 07:45 PM
tsunam1's Avatar
I didn't even waste my time taking it to the dealer, I worked there when I bought the car and already knew the rotors were crap, so I just upgraded them after I bought the car. I have 15,000 miles on the EBC rotors and redstuff pads, zero issues. GD7265 (11.7") Price: $247.15 (pair) @ http://www.perfectbrakes.com/ they have the SS 2.4 rotors listed incorrectly, select your car as a 2.0 SC, otherwise you well get the wrong ones. Then I hear the hawk pads are better than ebc redstuff, but I will wait till the redstuff wears out.
Old 08-09-2007 | 02:49 PM
CASol's Avatar
thats funny, the guy that owns EBC lives up the street from me.
Old 08-09-2007 | 04:43 PM
matt8478's Avatar
I have had this problem 3 times and the dealership finally said they would'nt resurface them anymore so no when I brake my stearing shakes a little.
Old 08-09-2007 | 05:09 PM
celicacobalt's Avatar
my ss 2.4 had the same issue but way before 10k, dealer basically said screw you after the 1st time helping.
Old 08-09-2007 | 07:37 PM
Schultzay's Avatar
all i've heard is that the OEM 2.4 Rotors are garbage and to just replace them with some power slot rotors or other aftermarket ones instead of wrestling with the dealearship
Old 08-09-2007 | 09:20 PM
tsunam1's Avatar
Could you rummage through his trash for the rear rotors? Thats cool though, you'll have to tell him the SS 2.4 has the same rotors as the SC, as his catalog is wrong, showing 2.2 rotors on 2.4, then let him use your car to test fit!
Old 08-10-2007 | 07:11 AM
WhiteSSBalt's Avatar
Not a Sebring
My stock rotors sucked way bad too, so I replaced them all with Powerslots and paired them up with Hawk HPS pads. Everything was fine for a while, but then about a week ago my car started making a terrible grinding noise from the front. It took the dealership forever to figure out the source, but they finally figured out it was the front left rotor. The rotor appears to be fine now that its off, but something was apparently wrong with it so I gotta buy another one now. Hm, I wonder if Powerslot warranties their products?
Old 08-11-2007 | 09:12 PM
tsunam1's Avatar
You can have the rotor turned, and I would check the pad for glazing, and if you don't follow the break in on performance pads then they will make noise, period. As far as a warranty I would contact powerslot before turning it, they may want to see the failure.
05-28-2022 03:47 AM
01-12-2016 12:01 AM
biniecki
10-25-2015 02:23 PM
nathan112i
09-30-2015 07:12 PM
09-27-2015 08:53 PM
Quick Reply: Xxx Issues with Braking System xxX
