zzp 2.5 downpipe
Old 06-24-2012 | 01:16 AM
  #51
noorj's Avatar
So since my car is a auto and urs is standard you will have 40 more whp? I don't think it would be that much of a difference. Did u run a 15.3 at the track or was that someone else,
It was a happy dyno as already stated. Say I have 190whp on a typical dynojet, you will have 10-15% more drivetrain loss. That would mean about 20-28 less whp, also every engine is different you can't say your at a certain HP by what I dyno by. Your car is not mine. Yes, I ran a 15.3 with a 2.6 60'. So when I learn to drive the car can easily pull a 14.8. What have you ran?
Originally Posted by mtbrent
No offense to noorjariri and his setup, but his numbers came from a known happy dyno in the area.
None taken. Have you been to innovative?
Originally Posted by CHEVRO_SS
ok thanks you have helped a lot...lol...and do i need a extra o2 bung to get a tune? or will i be ok b.c i prob wont get the extra bung
No problem, you don't need it but as everyone has said you should get it but it's your call man.
Old 06-24-2012 | 01:26 AM
  #52
DiabeticKripple's Avatar
Buy the ZZP catted downpipe, with an extra O2 bung and an O2 bung plug.
You may or may not throw a code with it. I did, but nothing a tune can't fix.
Also contact Terminator. He tunes cobalts and I think he is in Tampa.
Old 06-24-2012 | 01:49 AM
  #53
chevygirl2006's Avatar
I ran a 15.5 before I put the downpipe/header and the different tune. Idk what I run now
05-28-2022 03:47 AM
no_ss
10-18-2015 11:58 PM
justinchinn
10-02-2015 12:18 PM
nathan112i
09-30-2015 07:12 PM
09-26-2015 06:44 PM
Quick Reply: zzp 2.5 downpipe
