zzp 2 bar map sensor. Another thread :D
Old 04-16-2012 | 05:44 PM
Twoozofjuice's Avatar
So just wondering is the zzp 2 bar map sensor only for when you go supercharged? I just got one I bought from Heathkidder today and was wondering if it can replace the map sensor im using right now before I put the supercharger on. Thanks
Old 04-16-2012 | 05:46 PM
Matt M's Avatar
You can run it with any setup, but it needs to be programmed into the ecm, otherwise your car will run poorly.
Old 04-16-2012 | 05:50 PM
ahh so I would have to get tuned to put it on then? ok ill just wait till i put the sc on. Thanks
ineedacobaltss
11-07-2015 02:25 PM
09-27-2015 08:53 PM
Adiaz1ss
09-26-2015 11:51 PM
jas09ss
09-26-2015 01:06 PM
ChrisTutoki
09-24-2015 08:39 PM
Quick Reply: zzp 2 bar map sensor. Another thread :D
