zzp catless downpipe
does anyone have a vid of a 2.4 woth a catless downpipe with stock exhaust or with stock exhaust with the muffler changed, i havent had much luck on youtube, also wats everyones thought on the sound/ the noise level with a catless dp
Catless will be very loud and raspy. Search for catless LSJ's. They'll pretty much sound the same minus the blower of course. Use a high flow cat. Don't go catless unless you're doing a turbo build or something.
You can't do catless since your from ns anyway. I have a highflow cat and downpipe connected to my stock exhaust and it sounded preatty good. I've since swapped out my stock muffler for a dynomax muffler and it sounds good as well.
i can upload my video, zzp boosted, catless with full stock resonator.....
rev without hitting boost sounds just like with cat.... or even hitting boost
i have raced ppl with muffler and loud exhaust and they think a hybrid is passing them.......
i did 3 vid all with zzp turbo
stock full exhaust
stock exhaust with over the axle change
stock piping+over the axle piping+lnf muffler (this one sounds kinda bad..... because the car is running with a vacuum leak, and missfire)
ask ItalianJoe, the car was a sleeper and fun to drive, no sound at all and the car will just pick up and move.
stock full exhaust
