ZZP Header & DP noise???
Old 02-01-2012 | 06:09 PM
GRok25's Avatar
Originally Posted by RooTBeeR
im gonna say its just rasp/cylinders firing more audible from better/larger/thinner parts
if its a leak, it'd be audible at idle/low rpms too, start it(when cold if possible), pop the hood and stick your head in there over/near the header and listen for ticking. and or put it on jacks/ramps and do the same thing to check the dp/cat back for noise
I hear slight ticking when i have it idling before i drive it but after 20 min of driving i got out and it went away.
like i said before it is realy loud when i first start to drive it or if i drive it and the car has been sitting a couple of days. but it calms down as it warms up. never hear any vibrations before 3k rpm though
Old 02-01-2012 | 06:22 PM
GRok25's Avatar
Old 02-01-2012 | 10:54 PM
GRok25's Avatar
Old 02-03-2012 | 09:30 PM
-TurboSS-'s Avatar
My 3 inch exhaust knocks against the axle or something when I downshift, other then that it's fine. It does change tone above 3k or so but I wouldn't call it a vibration and it sounds good still.
Old 02-06-2012 | 12:45 AM
GRok25's Avatar
Got my friends opinoin at an exaust shop. says its the muffler. its being caused because the hi-flow cat is like 1/2 the size of the stock one therefore far less restrictive. im going to give corsa a call and see if this would be included with there lifetime warentee for a replacement muffler
biniecki
10-25-2015 02:23 PM
no_ss
10-18-2015 11:58 PM
justinchinn
10-02-2015 12:18 PM
jimbofug007
10-02-2015 12:06 PM
09-26-2015 06:44 PM
Quick Reply: ZZP Header & DP noise???
