zzp mid-length header aftermath less than 20hrs after install
Old 05-01-2008 | 07:03 PM
Shaun927's Avatar
i was driving in the underground parking lot at yorkdale mall and all of a sudden the bolts that connect the dp to the header broke and i was setting off alarms at idle; so went out and bought stronger bolts but the gasket i bought for it wasn't the right size but it should be good enough until i get iget a replacement gasket; my question is, has anyone had the problem; and how long did it it take zzp to ship u another gasket?
Old 05-01-2008 | 07:05 PM
IonNinja's Avatar
are you talking about a gasket problem or a bolt problem?
if bolt problem, it has been addressed many many times before
in regards to the gasket, you should be able to get a replacement from your dealership
Old 05-01-2008 | 07:08 PM
Shaun927's Avatar
not the gasket for the headers im talking about the gasket for the zzp downpipe it fell off when the bolts broke the stock one was 3 bolt pattern the zzp is 2 bolt pattern
Old 05-01-2008 | 07:10 PM
Jimmys2007CobaltSS/C's Avatar
i set off car alarms all da time but not at idle
Old 05-01-2008 | 07:17 PM
Shaun927's Avatar
lol the idle was loud when the bolts broke the dp was just hanging
the bolt issue is done i just need a new gasket
Old 05-01-2008 | 07:18 PM
i had that problem the bolts are cheap i had to replace them
ProJecTX's Avatar
I had the same exact thing happen, i ended up buying another gasket through them and getting it over nighted (took a little longer then I thought it would w/ overnight) If you talk with them might be able to work something out. you never know.
thx
-Brad
Old 05-01-2008 | 07:31 PM
Shaun927's Avatar
i'll give them a call but i gotta admit it sounded pretty mean i shut up all the ricers around my city lol
Old 05-01-2008 | 07:37 PM
ProJecTX's Avatar
Hell ya, my car never sounded meaner!
With a busted bolt & gasket
http://videos.streetfire.net/video/R...ust_149460.htm
with stronger bolts + new gasket (GMP touring exhaust by the way)
http://videos.streetfire.net/video/C...rDP_150930.htm
-Brad
Old 05-01-2008 | 08:14 PM
Shaun927's Avatar
mine didn't sound that raspy but if it wasn't for the w/e law it is about the noise level i would have just left it i loved the looks i got espscially since no one expects it from a stock looking white 2.4
i have to call zzp tomorrow since they're closed
Old 05-02-2008 | 02:12 PM
celicacobalt's Avatar
are the stock bolts strong enough fi you are just replacing the downpipe and not the header?
Old 05-02-2008 | 04:09 PM
hubes's Avatar
Did yours come with grade 9 bolts? if not thats the problem, if so what did you get that you think is stronger?
Old 05-02-2008 | 04:13 PM
ProJecTX's Avatar
My ZZP dp/header came with grade 9 bolts and they still broke... i'd recommend bigger bolts and locking washers... cost me about 6 bucks at the hardware store...
thx.
Old 05-02-2008 | 05:32 PM
Shaun927's Avatar
i got the high tensile bolts from brafasco i told him what happend and he gave me 4 bolts, 4 nuts and 8 washers for free
Old 05-06-2008 | 12:13 PM
BULLETSSMOKE's Avatar
LOL, good to see another person with ZZP problems. Yeah, 3 minutes after I installed my those ***** broke. gg ZZP for **** quality.
Old 05-06-2008 | 04:49 PM
Shaun927's Avatar
there sending me new gaskets and stronger bolts but i dun get y they didn't give you the stronger bolts in the first place, but all in all im impressed with there header a big difference from stock
Old 05-06-2008 | 04:55 PM
ssweeet's Avatar
For your 2.4L what exhaust piping (inches) do you have and what about for your header and downpipe? I have been interested in the zzp combo for some time now but I am afraid of all the problems that come with them.
05-28-2022 03:47 AM
nathan112i
09-30-2015 07:12 PM
z28addiction
09-28-2015 12:03 AM
09-27-2015 08:53 PM
09-26-2015 06:44 PM
Quick Reply: zzp mid-length header aftermath less than 20hrs after install
