ZZP Stage 2 turbo
Old 06-04-2012 | 12:32 AM
cobalt_sport08's Avatar
ZZP Stage 2 turbo
I didn't just realize this but since having a job I want to buy some parts well I was going to get a DP(ZZP 2.5 catted) and header(bad-mad) but if eventually I want to go turbo so wouldn't buying them be pointless??
Old 06-04-2012 | 12:40 AM
BLAZIN07SS's Avatar
I'm too JDM for you
Yes.
Old 06-04-2012 | 12:42 AM
EXsoccer1921's Avatar
you could still get a catback. their turbo dp's bolt up to their catbacks
Old 06-04-2012 | 12:46 AM
ok thanks
now I need help on what to pick..
Old 06-04-2012 | 12:47 AM
I was thinking about getting a Corsa I really like that deep tone or will that fit after I go TC?
Old 06-04-2012 | 12:52 AM
i'm not sure. depends on the flange used. but iirc the downpipe ends right where majority of the catbacks start
Old 06-04-2012 | 01:15 AM
kdub1492's Avatar
You could always get it then say screw the flange and just have it welded on
Old 06-04-2012 | 09:33 PM
haha that too.. i dont want to sound troublesum but could someone explain to me the different options when selecting the turbo...
like the model, option 2-6 and core change.. ZZPerformance - 2.2/2.4L Turbo Kit #ZZ-2224TK
Old 06-04-2012 | 09:43 PM
Edit
I just scrolled all they to the bottom and saw the info for each selection..
still dont understand air to air vs air to liquid (im goggling)
OPTION 2: what is the atmosphere dump??
OPTION 3: dont think i want a boost controller..
OPTION 4: ill stick with the ZZP BOV,
OPTION 5: 2.5" vs 3" catted??
OPTION 6: no idea
CORE CHANGE im auto so they'll send me the PCM and TCM for $200
Old 06-04-2012 | 09:44 PM
noorj's Avatar
You'll want air to air, simpler and better for a daily
2) If you need to pass emissions and don't know anybody have the wastegate recirculate back into the exhaust.
3) You'll want a boost controller to have better control of what psi you want to run at.
4) Same thing, get the ZZP and save
5) Again if you need to pass emissions get a catted DP, 2.5 inch is good enough for the S256 and will bolt up to your catback
6) If it's a daily and not on a built engine the S256 is plenty capable.
If you plan on getting it tuned (HPT or Trifecta) don't worry about the core charges you want need them
Are you going to be doing the install?
Old 06-04-2012 | 09:53 PM
ok i've read the air to liquid is more maintenance
(2) is that what the turbo DP is for??
and there's a local car dealer and they apparently love working on fords and chevy's so i was going to talk to them and see how much in install would run me.. idk if they tune but if not probably trifecta since its cheaper
Old 06-04-2012 | 10:25 PM
noorj's Avatar
No, The downpipe is where the exhaust gases from the turbo go. The wastegate controls how much exhaust gas actually goes through the turbo, some are forced to bypass the turbo and go down the dumptube. This can be recirculated back into the exhaust to pass emissions or to the atmosphere and be badass
Old 06-04-2012 | 11:01 PM
bluebalt07's Avatar
Atmosphere dump is also a lot louder at wide open throttle because you are basically having exhaust bypass the exhaust system so it comes out really loud
Old 06-04-2012 | 11:04 PM
ha im not to concerned about passing emissions.. plus its cheaper =)
and loud turbo sound nice!
Old 06-04-2012 | 11:16 PM
Will there be a power difference between the 2.5 and 3 inch DP and catted vs non?? I know non catted is less restriction but that also means NOISEE i dont want a shitty sounding exhaust..
Old 06-04-2012 | 11:19 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Really no offense dude but read up on turbo systems before you dive into one. Garrett has great information on their website on everything from start to finish. It will really help you gain an understanding on what you're getting into.
Old 06-04-2012 | 11:41 PM
Thanks I know I need to do my research
Old 06-04-2012 | 11:50 PM
bluebalt07's Avatar
The turbo itself will quiet the exhaust down some also so that's something to think about. The atmosphere dump will probably be louder than the catless downpipe
Old 06-04-2012 | 11:52 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Not probably. It will. Lol it's all you will hear at WOT
Old 06-05-2012 | 01:15 AM
would this be an example?? Cobalt SS from hell! - YouTube
its what i think of when i think atmosphere dump
Old 06-05-2012 | 01:16 AM
ok so what about the size does it make a difference??
Old 06-05-2012 | 01:28 AM
noorj's Avatar
This. And searching this forum.
Old 06-05-2012 | 01:45 AM
im still reading Garrett
Old 06-05-2012 | 03:26 AM
DFZ24's Avatar
I have the wastegate recirculate back into the exhaust, makes the car quiter....
yes go air to air, is simpler, air to liquid is good but is too much clutter in the engine bay.
3)later in time you will want a boost controller... i thought the same and ended up buying a hallman boost controller, recommend by Blazin07SS
4) i only had one option at the time was tial bov
5) catted also will be quiter, i have catless, again it was the only option at the time.
my goal was a quite boosted car
BLAZIN07SS knows what im talking about lol
Old 06-05-2012 | 08:45 PM
Nice thanks man!
Quick Reply: ZZP Stage 2 turbo
