3rd GEN Projectors $190 with anti glare mod
#76
#77
What''s your warranty on your Projectors?
...Because i have had Gen3's and know how there made.....
this should be answered here.
I was just wondering if your headlights had an issue with multiple stress cracks or whatever they may be appearing on the headlight casing. I purchased a set of headlights that look very similar to yours, but within the first week they started getting all these tiny elongated cracks that are impossible to remove. I would just be extremely upset if I were to pay for another set of headlights and have all these tiny cracks show up on the casing. If that does occur with your headlights; does that fall under warranty? Other than my fear of these cracks occuring I am extremely interested in purchasing a set with the HID kits installed, but I need to have some form of reassurance that this will not occur, or it will be taken care of if it does happen.
Last edited by EcoTecDriver; 03-21-2010 at 01:18 AM. Reason: Automerged Doublepost
#79
The only way we can do any warranty on the projectors is if we ship them straight from distributor. Of course if we did that, then we can't do the anti-glare mod.
#80
#82
its not the bulbs cracking the lens...its the cheap plastic the lens is made from+the sun/heat= cracking.
#86
Oh yea, and now the pieces that hold the projector to the headlights.. the ball and socket joint piece.. it broke, and the projector bounces when i hit bumps.. THANKS!!
#87
yo operatic, what size are the Halo rings in these suckers, im looking to change my halo's out and dont know what sizes i need
bump for some1 to answer that question
#88
Hi there I'm really interested in these headlights, and want to get the HID's,
so what is the deal with these cracking headlights, are there more people with this issue.
I have a vary stiff ride with my suspension and I don't want to end up with garbage.
any imput would be much appretiated
Thanks
Thanks
#89
Thanks
Thanks
The other problem is, the spidering lens is notorious across all projector headlights we've seen for the Cobalts. The only "good" solution is to swap the lens off the factory headlight onto the projector headlight.
In the meantime, I've got an OEM Cobalt headlight that's popped open so I'm waiting on a set of Morimoto projectors to come in to see how they fit.
#90
... Now my 3rd gens have two lens' that are cracking, spidering, and now their finish is peeling off on the outside. all in less than a year of owning them... do you have extra lens laying around? i dont have my stock lights
#92
And the only ones I can get would likely be Depo or Eagle Eye reproductions and that would require buying the entire headlight assembly just for the lens :|
#97
No real tricks to be honest. We usually just use T-Taps when we tap into the turn signal/parking lights in case we have to remove the headlight.
#98
i dont have the stock wiring harness with the blue half moon adapter on it. Considering I am upgrading from 2nd gens to 3rd gens...got any tips on how to make this work?
heres a member with a similar problem:
https://www.cobaltss.net/forums/show...alling+2nd+gen
#100
I got mine from Pro Tuning Lab they have the CCFL halo's cost a bit more but they are brighter and last longer, I bought the 3rd Gen style and but HID's in both high and low (35W), and have had them installed for a year, no cracked or melted lense.
these are the ones i got:
Chevy Cobalt / Pontiac G5 05-09 CCFL LED Projector Headlights - Black with HID Kit
right now on sale with HID for $290
