3B Spec 3B Spec is a Supporting Vendor
Contacts: operatic
3rd GEN Projectors $190 with anti glare mod
Old 03-21-2010, 01:13 AM
  #76
operatic's Avatar
Originally Posted by Renesis
do you plan on offering something similar with the 4th gen projectors?
Unfortunately none of the distributors we work with carry the 4th gen's.
Old 03-21-2010, 01:17 AM
  #77
EcoTecDriver's Avatar
What''s your warranty on your Projectors?
...Because i have had Gen3's and know how there made.....
Originally Posted by Life On Top 24
I was just wondering if your headlights had an issue with multiple stress cracks or whatever they may be appearing on the headlight casing. I purchased a set of headlights that look very similar to yours, but within the first week they started getting all these tiny elongated cracks that are impossible to remove. I would just be extremely upset if I were to pay for another set of headlights and have all these tiny cracks show up on the casing. If that does occur with your headlights; does that fall under warranty? Other than my fear of these cracks occuring I am extremely interested in purchasing a set with the HID kits installed, but I need to have some form of reassurance that this will not occur, or it will be taken care of if it does happen.
Originally Posted by operatic
PM sent.
this should be answered here.
Last edited by EcoTecDriver; 03-21-2010 at 01:18 AM. Reason: Automerged Doublepost
Old 03-21-2010, 12:13 PM
  #78
bump for a answer
Old 03-27-2010, 01:46 PM
  #79
operatic's Avatar
The only way we can do any warranty on the projectors is if we ship them straight from distributor. Of course if we did that, then we can't do the anti-glare mod.
Old 03-27-2010, 03:07 PM
  #80
So in other words when they crack which most of them do,if not all of them, we are stuck with it...
Old 03-27-2010, 03:16 PM
  #81
AWD > FWD
TommyP's Avatar
ya pretty much. Put hids in them right away, that should help prevent some cracking. Also replace your side marker and turn signals with leds since they run cooler. That side marker bulb actually gets pretty damn hot.
Old 03-27-2010, 04:02 PM
  #82
its not the bulbs cracking the lens...its the cheap plastic the lens is made from+the sun/heat= cracking.
Old 04-06-2010, 01:16 PM
  #83
Black SS/SC 06's Avatar
Coupon code for the projector/hid combo didn't work for me
Old 04-20-2010, 12:23 AM
  #84
operatic's Avatar
We've kind of disabled the coupon code :I
I can probably put something together though, we have a black Cobalt projector laying around.
Old 04-20-2010, 02:29 PM
  #85
Shenanigans
It's not like the German's kidnapped your lights or anything
Old 04-20-2010, 02:40 PM
  #86
ddsscobalt's Avatar
x2 still waiting for an answer... I have had cracks since a month of owning them.. Operatic said i could polish them out, which was nonsense to hear.. I baked them in the oven and put the lenses from my 1st gens on there.. now they are cracking too.. two sets of headlights, one from ebay, others from operatic.. both stress cracks... what a waste of money for a non warrantied cheap product...
Oh yea, and now the pieces that hold the projector to the headlights.. the ball and socket joint piece.. it broke, and the projector bounces when i hit bumps.. THANKS!!
Old 05-09-2010, 08:27 PM
  #87
Gestapo007's Avatar
yo operatic, what size are the Halo rings in these suckers, im looking to change my halo's out and dont know what sizes i need
bump for some1 to answer that question
Old 05-30-2010, 12:28 AM
  #88
player_1's Avatar
Hi there I'm really interested in these headlights, and want to get the HID's,
so what is the deal with these cracking headlights, are there more people with this issue.
I have a vary stiff ride with my suspension and I don't want to end up with garbage.
any imput would be much appretiated
Thanks
Old 05-31-2010, 09:21 AM
  #89
operatic's Avatar
Thanks
The cracking/spidering is on the lens itself. It's something that got brought to our attention after we started selling them and unfortunately it's damn near impossible to get them replaced by the distributor (I've tried, only ever got 1 replaced in the last year and that was a 6 month process).
The other problem is, the spidering lens is notorious across all projector headlights we've seen for the Cobalts. The only "good" solution is to swap the lens off the factory headlight onto the projector headlight.
In the meantime, I've got an OEM Cobalt headlight that's popped open so I'm waiting on a set of Morimoto projectors to come in to see how they fit.
Old 05-31-2010, 09:44 AM
  #90
ddsscobalt's Avatar
... Now my 3rd gens have two lens' that are cracking, spidering, and now their finish is peeling off on the outside. all in less than a year of owning them... do you have extra lens laying around? i dont have my stock lights
Old 05-31-2010, 10:51 AM
  #91
Gestapo007's Avatar
gotta put OEM lenses on man, every single aftermarket lens has problems.
Old 05-31-2010, 11:28 AM
  #92
operatic's Avatar
Sorry, I don't :T
And the only ones I can get would likely be Depo or Eagle Eye reproductions and that would require buying the entire headlight assembly just for the lens :|
Old 05-31-2010, 11:21 PM
  #93
player_1's Avatar
so if I place my stock lense on it after I won't have any issues?
Old 06-01-2010, 02:37 PM
  #94
Gestapo007's Avatar
^No sir, if anything maybe itll fog a bit, but your good to go man. just do that
Old 06-01-2010, 06:29 PM
  #95
player_1's Avatar
thanks for the info, I think I'll pain the inside to match the body colour when it's time to change the lense
Old 07-22-2010, 09:23 PM
  #96
Brenden Griswold's Avatar
is there a how-to on installing the LEDs and HALOs? I know you just wire it up to the brown wire, but how do you do that? Are there any special tricks?
Old 08-02-2010, 02:45 PM
  #97
operatic's Avatar
No real tricks to be honest. We usually just use T-Taps when we tap into the turn signal/parking lights in case we have to remove the headlight.
Old 08-02-2010, 03:38 PM
  #98
i dont have the stock wiring harness with the blue half moon adapter on it. Considering I am upgrading from 2nd gens to 3rd gens...got any tips on how to make this work?
heres a member with a similar problem:
https://www.cobaltss.net/forums/show...alling+2nd+gen
Old 03-08-2011, 06:51 PM
  #99
smithers80's Avatar
Can I get a set of these projectors still ?
Old 03-09-2011, 08:20 AM
  #100
player_1's Avatar
I got mine from Pro Tuning Lab they have the CCFL halo's cost a bit more but they are brighter and last longer, I bought the 3rd Gen style and but HID's in both high and low (35W), and have had them installed for a year, no cracked or melted lense.
these are the ones i got:
Chevy Cobalt / Pontiac G5 05-09 CCFL LED Projector Headlights - Black with HID Kit
right now on sale with HID for $290
Quick Reply: 3rd GEN Projectors $190 with anti glare mod
