so after a few months of use
Rent me! per hour
my headlights don't work.
gee. this is nice.
worked fine last night, not now.
come to find out, the jumper harness that is supplied with the kit is overheating. i find this odd. i really do. it melted the fuse to the fuse hold and expanded to the point where i have to cut the wires and redo half of the kit to get them to work again.
between wires being backwards on the harness, to the jumper harness trying to burn my car down. this is a massive failure.
hi. see a problem here?
gee. this is nice.
I had to do that on my headlight harness.The pins keep breaking off and causing the running light and headlight not to work so I had to run jumper wires bypassing the headlight.Yours sounds like more of a pain.
Rent me! per hour
i'll probably just give this away to someone after i get new 9007 bulbs. sorry. HID's are not as important to me as having reliable transportation. too bad the escort doesn't have 9007 bulbs. id totally put em in there
u are right nor do u want one or both to go out while driving thus resulting in a crash into you or a nice ticket by the cops...sorry to hear about it though..now im rethinking if i even want hid's
Rent me! per hour
the fuse holder on the jumper harness to the relay is what is melting due to excessive heat from the hid kit.
oem bulbs. i have one, the other is in the girlfriends car. she had a bulb out, so i used mine to fix hers.
i'll post pics tomorrow of what's left of the relay and fuse holder
Rent me! per hour
as many kits have been sold through this board. i figured someone representing this company would do something about it. guess not. 2 days down. crickets on their end.
Hmm interesting the only issue I have is there is an yellow circle on my driverside HID (I have 5000k's) went I turn them on, not to mention I never did figure out why the DRL fuse kept blowing out after a few days.
