Balance shaft elimination kit
Old 04-29-2008 | 02:25 PM
slindborg's Avatar
hmmm I contacted gmtuner and cloyes but neither could help bar cloyes saying they supplied 3 sets to lotus and that was all... circao $5K in prototype tooling etc.
so where the heck did you get one from and how much was it lol
Old 05-23-2008 | 04:10 PM
bolus's Avatar
Sorry, I missed this post. I got the short chain and new guide directly through GMracing. the kit is XGH676 and you need to cant them through the GM tuner source website. you can use this form:
http://tunersource.gmblogs.com/ecote...ical_questions
I ended up talking with Carmen Smith. She is the program manager for the sport compact drag racing team.
Old 10-15-2010 | 10:33 AM
hawlyns711's Avatar
anybody read this thread and consider doing this?
Z22SE.co.uk • View topic - Removing Balance Shafts
what you need to do is this
step 1; find a 30mm socket and a 15" long 1/2" extension bar.
step 2; place the engine up on end onto the flywheel and slide the socket into the front balancer shaft hole.
step 3; note the position of the block face on the extension bar, then remove the bar and fit some masking tape to the bar so you can mark the height of the block.
step 4; refit the bar and mark the face of the block onto the masking tape, spin the bar so the mark is all the way round
step 5; remove bar (again) and then mark a new line 7.5mm further away from the socket
step 6; refit the bar into the block, you now should have the new line 7.5mm from the block face
step 7; using a BIG hammer carefully knock the rear bearing towards the flywheel by 7.5mm (until the new line is level with the block)
step 8; repeat step 7 for the other bearing
job done cheers..
this will block off the rear oil ways and mine has 80 psi oil pressure at tickover
ps: the bearings need a good hit to move :roll:
Old 10-18-2010 | 10:33 AM
hawlyns711's Avatar
05-28-2022 03:47 AM
hacadacalopolis
10-28-2015 06:09 PM
dennis69
10-20-2015 04:49 PM
DANRICKARD
10-01-2015 12:08 AM
09-28-2015 12:51 PM
Quick Reply: Balance shaft elimination kit
