F35 - Project 6k sidestep
Old 10-18-2016 | 06:25 PM
  #201
LNFwagonSS's Avatar
Selling my braced 4.45
I still have my first gen brace design trans with 4.45 gearing. Getting ready to reassemble. Pm if interested
Old 10-18-2016 | 07:09 PM
  #202
mrbelvedere's Avatar
Originally Posted by LNFwagonSS
Well, if I could've pulled my head out of my ass for more than one pass, it would've made an 11 second pass. I was simply not mentally ready for 1/4 mile. Kept forgetting about my 3-4 shift because I'm hard wired for 1/8. Seriously pathetic lol, I mean who forgets to shift?! The worst run was when I panicked to shift to 4th and I NLS from 3rd to 2nd!!! Dumbest most noob **** I've ever done. I got lucky, trans and engine are still fine and I went out and made a 12.1 pass afterward. WHEW! Nonetheless, the car did excellent. Was pulling 1.7 60' all day with ease. So close to 11s. BUT, I can now claim to be the fastest stock chassis HHR on the planet, so there's that.
BTW I'm not sure how many transmissions can hold together after being NLS from 3rd to 2nd...but this one sure does
nice 60ft im pulling 1.82 right now
Awesome job on the run and I'm really envious on your 60's that's just awesome. You definitely have the launch way more figured out than I do as I was still laying down 2.05 on slicks. On a fwd stick car there is a lot that goes on, running a 1/4 mile. I was skeptical that you would be able to run out the 1/4 in 3rd and it sounds like you couldn't. I can't believe your motor or trans didn't pop on that shift. Glad you were able to drive it home.
I do it on a 24in tall slick 7300rpm in 3rd you want to be in 4th at/over your shift point
Thanks! It's the turbos fault I can't run out the 1/4 in 3rd I believe. The ratios and tire size are able to do it if I could rev over 7k but that's just not feasible with this tiny turbo
man up you can do it
I'm not so sure you would want 3.82 for drag racing unless the car was gutted for weight loss and/or a fast spooling turbo was used. As others have mentioned, the 1-2 shift is not the most ideal ratio change (especially with 3.82 fd) unless you have the power down low to back it up, then it becomes very useful.
As far as 3rd gear pulls, I wouldnt discount the 3.82 just yet unless we're talking 500+tq. I'm hoping I can make that gearing usable for the 450tq cars with a reasonable tq curve but that has yet to be determined or proven. Time will tell.
the 3.82 is junk for racing period
3.82 would give you the best chance at revving out and finishing in 3rd. That's all I was trying to say. I think the 4.05 sounds like the perfect in between trans.
Was just playing around today and tried going 2nd to 4th (shifted to 3rd first then down without letting clutch out) and at 6,000 when I got to 4th I was at about 3,300, with the 4.45. Wonder what 6,700 would net. I know the ratio isn't great for power, but not shifting 3-4 towards the top end and slowing the car down in the process would be worth trying once. I'm sure it's still faster going through the gears and revving them out especially if you are going to nls.
4.45 is a better final drive for making power the more mechanical advantage you can gain the better off you are
With the 4.45, a 1-3 shift would be much more effective in that scenario. You know how it feels starting around 40 in 3rd
NLS with this trans is virtually effortless. This thing NLS so smooth. I shift really f****** fast and the trans accepts it every time unless I fubar the pattern. So the 3-4 shift can't be holding me back much. Maybe I just need to throw the 3.82 gears in for next year with the TQ of the 6758 Zfr and see what it can do. Hmmm
skipping gears is not effective way to get a better e.t. your loosing mechanical advantage when you do and overloading the clutch and trans
Old 10-18-2016 | 07:11 PM
  #203
Originally Posted by Omiotek
Strapping the front will virtually eliminate weight transfer with a good set of drag bags in the rear. I thought about pioneering a super secret setup for these cars but i doubt its going to happen. Its something ive discussed before but i dont see enough hardcore racers to consider doing this and a one off will be huge cage.
Cough... you need a sheet metal intake and piping from me..... cough cough
no it doesn't your limiting how far it can travel not eliminating travel
Old 10-18-2016 | 07:40 PM
  #204
LNFwagonSS's Avatar
1.7 60' ain't to bad for an hhr eh. I'd say the rear setup is quite effective
It's pointless to try and run out the gears with power dropping at 6300, especially when I shift faster than the speed of light.
Of course skipping gears is not effective for gaining ET
Old 10-18-2016 | 10:34 PM
  #205
63 Nova SS's Avatar
Mr B- what kind of mph are you at, at 7300?
I tried last year on my 3.82 to rev it out even though I knew the hp peaked at about 5900, just to see if I could do it. I ran 1st and 2nd to 7,000 and ran 3rd to 7,250 and started bouncing off the rev limiter 30ft from the lights and the car started slowing down and ran through at 115. There is no way I can rev out in 3rd on the 4.45. I finish in 4th at about 5350rpms shifting out of 3rd at 6,500.
Old 10-19-2016 | 12:51 AM
  #206
Omiotek's Avatar
I should of worded it better lol.
Old 10-19-2016 | 04:55 PM
  #207
the rear setup is holding you back causing it to bounce try a different shock that has a much much slower rebound rate then 50/50 as for your shifting its not that fast and running it out a little farther will help
on a 405 final drive im pulling 116 almost 117 around 7500 rpm in 3rd going through the traps but I am also shifting @ 8100
Old 10-19-2016 | 04:58 PM
  #208
63 Nova SS's Avatar
8100, yikes. Bet that thing screams with a supercharger.
Did you custom make your front strap suspension setup?
Old 10-19-2016 | 07:46 PM
  #209
LNFwagonSS's Avatar
It's not bouncing anymore since I strapped it, check out the video on the previous page. Slower rebound shocks would be a great addition though. Which would you suggest?
If I go to 1/4 mile again with this turbo, I will try to run it out in 3rd. Hopefully I'm more mentally prepared the next time I take on the 1320.
Old 10-19-2016 | 09:39 PM
  #210
63 Nova SS's Avatar
It's not bouncing anymore since I strapped it, check out the video on the previous page. Slower rebound shocks would be a great addition though. Which would you suggest? If I go to 1/4 mile again with this turbo, I will try to run it out in 3rd. Hopefully I'm more mentally prepared the next time I take on the 1320.
I have Koni rears and am going to play with the damping on them, but not probably till next spring as the track is closed for the year. Sadly I didn't think about doing that till a couple weeks ago. I know they are adjustable from dead soft to stiff. Only have them in the rear though.
Old 10-19-2016 | 09:45 PM
  #211
slapbetcommissioner's Avatar
What mph are you getting out of first gear at your shift point? And second gear?
Old 10-19-2016 | 09:55 PM
  #212
don't need to yet I leave @ 5500 and the car seems to set level I do need to replace the shocks and struts the old ass progress springs have taken their toll on them
looks like its bouncing to me as for shocks you want adj rebound and compression you want to compress somewhat quick but rebound slow to keep the bounce out of it you need the chassis to work and if you need to limit it do it in the front so its easier to tune
hell if I know I just worry about trap rpm and mph
Old 10-19-2016 | 11:50 PM
  #213
Sorry I meant lnfwagonss I was wondering what the 4.45 first and second gears looked like.
If a second gear launch was feasible or even worthwhile.
1.760ft it may not be necessary.
Old 10-20-2016 | 07:08 AM
  #214
63 Nova SS's Avatar
Sorry I meant lnfwagonss I was wondering what the 4.45 first and second gears looked like. If a second gear launch was feasible or even worthwhile. 1.760ft it may not be necessary.
It will bog in 2nd gear out of the hole because 2nd gear doesn't have enough gear ratio. 1st gear with a 4.45 and turbo is to short. You could do it but you will have to slip the clutch for quite awhile to get/keep the rpms up and it would hurt your times to much. Quaffe 6 speed conversion with 4.45 gears would be perfect. But it's $4300 installed. I think it's got to best ratios on any f35 or the f40.
Old 10-20-2016 | 09:37 AM
  #215
Ok I know you can't do it on a 3.86 and a 4.05.
Knowing first gear is stupid short on the 4.45 I ss curious if second was short enough.
Old 10-20-2016 | 01:16 PM
  #216
LNFwagonSS's Avatar
I'm running 4.05 now. I was running the 4.45 last year but I don't remember what speeds . It really all depends on the tire used. On my 26" radials with 4.45, it felt similar to the 4.05 with 24.5" tire. If any of you drag race with the 4.45, my first choice would be a 26" slicks for best rollout. Makes sense on paper.
I did try a 2nd gear launch on the 445 once. On a 26" tire it didn't work, fell on its face and gave the clutch a hell of a workout. Even on a 24.5 tire, I don't think it would work
Old 10-20-2016 | 06:36 PM
  #217
63 Nova SS's Avatar
Sorry had to show someone what the bags look like installed. That's what they look like deflated.
Old 11-02-2016 | 04:18 PM
  #218
LNFwagonSS's Avatar
Last Friday was the last test and tune of the season at my local track so I couldn't resist going and beating on this trans one last time. Even with the 1.5 month set back in the middle of the season, I made a TON of passes on this trans NLS and all. I'll see if I can find all my slips from this year for a final tally. Looking forward to next year for sure!
Old 11-02-2016 | 10:00 PM
  #219
63 Nova SS's Avatar
Three of your 4 passes were 7.85. Man that thing is consistent. You keeping the 4.05 in it next year? Oh and try not to take 6 weeks off next year.
Old 11-02-2016 | 10:34 PM
  #220
LNFwagonSS's Avatar
Yea the setup is working well and smooth NLS really helps the consistency. And I drive the hell out of it the same way everytime. Our local track prep always fades off quickly which is why my first pass was the best.
I'm pretty sure I'll stick with the 4.05 next year depending on how well it works with a bigger turbo that has more lag. I might take some time off anyway so I can throw some pistons and rods in. Hopefully that doesn't take 6 weeks lol.
Old 12-30-2016 | 09:27 AM
  #221
LNFwagonSS's Avatar
UPDATE : 550Tq R&D build commence
Good things to come
Old 12-30-2016 | 10:27 AM
  #222
Vented trans case, i like it.
Old 12-30-2016 | 10:47 AM
  #223
LNFwagonSS's Avatar
Cooling mod
Old 12-30-2016 | 10:22 PM
  #224
63 Nova SS's Avatar
Nice
Old 01-16-2017 | 01:43 AM
  #225
LNFwagonSS's Avatar
Design of the latest modifications is complete. These are VERY important output shaft modifications which will align 3rd gear and replace the crush sleeve with a larger, tighter fitting spacer which must be custom sized per gearbox. I will be completing a 445 lsd build utilizing these parts within a couple weeks. I'll post up some pics so you all can see how big of a difference the rigidity of the output shaft is compared to stock.
Last edited by LNFwagonSS; 01-16-2017 at 07:06 PM. Reason: Because admin made me do it
