How it's supposed to be done.
Old 03-10-2010 | 11:51 AM
1badBlueberrySC's Avatar
I talked to him last night.... did you guys notice the freakin clean bearings there....
NO WEAR... that is how it should look.
And for all those that say he can't tune for ****..... Thats proof in the puddin' right there!
Old 03-10-2010 | 12:03 PM
ralliartist's Avatar
looks awesome, can't wait to see numbers.
Old 03-10-2010 | 12:06 PM
Zach06CobaltSC's Avatar
Why no pics of the ported head =/
Old 03-10-2010 | 12:07 PM
PRND3L's Avatar
i did notice that.
Old 03-10-2010 | 12:16 PM
PSHHH's Avatar
will you be at the CED meet by any chance? would love to see the car in person...other than that nice work keeping the motor up to par.
Old 03-10-2010 | 12:18 PM
thefishyisblue's Avatar
Old 03-10-2010 | 12:22 PM
northvibe's Avatar
ohhh baby I love your waysss...everyday
Old 03-10-2010 | 12:54 PM
383_Stroker's Avatar
Wash your car!
Otherwise.. Exxxxcelllent!
Old 03-10-2010 | 01:08 PM
steddy2112's Avatar
Fkn awesomesos
Old 03-10-2010 | 01:15 PM
alexx's Avatar
hey area, do you mind me asking what pully your gunna b running on the tvs once your done with the engine building because im actually doing pretty much the same thing and i have a tvs so i was just wondering what size your gunna b running
Old 03-10-2010 | 01:27 PM
  #36
Stiner's Avatar
Nicely done hopefully you dont crack a sleeve
Old 03-10-2010 | 06:11 PM
  #37
Tennpenn83's Avatar
very nice area. i was beginning to wonder if you were ever going to build it up.
definitely sub'd...
Old 03-10-2010 | 06:40 PM
  #38
Changing the pistons and not the sleeves, not saying it's going to happen, but I HOPE his sleeves don't crack.
I have noticed that A LOT of people who change there pistons and not there sleeves at the same time have cracked there sleeves shortly after.
Old 03-10-2010 | 06:43 PM
  #39
JapEatr's Avatar
South Central *********
Great work Area!
Old 03-10-2010 | 06:44 PM
  #40
DarkCobalt13's Avatar
The magazine is gonna have to do an updated article now.
Keep the good **** coming bro!
Old 03-10-2010 | 06:45 PM
  #41
SS/SC Crazer's Avatar
oh u suck!!!
Old 03-10-2010 | 11:08 PM
  #42
06_SIC_SS's Avatar
u gonna run supertech valves?
Old 03-10-2010 | 11:47 PM
  #43
Jrhdpaintball's Avatar
replaced rod bearing anyway even tho they look awsome? if so stock?
  #44
TommyP's Avatar
AWD > FWD
Old 03-11-2010 | 11:16 AM
  #45
Originally Posted by 06_SIC_SS
lowering the psi through the ported head should help with avoiding this
LOL
All that is doing is lowering PRESSURE BEFORE THE HEAD. That's where boost readings are read from. A ported head will allow more air to get inside the cylinders, which in turn you add more fuel, which in turn makes more power, which in turn increases cylinder pressure. Which in turn a lot of people have split sleeves, including me.
I doubt Bryan will crack a sleeve though. HIGHLY doubt.
Old 03-11-2010 | 12:46 PM
  #46
Blown 4-banger's Avatar
You've done it now, you've cursed you car. Once Ecotecs are built, that's when they blow up. Look at Paul's car, didn't blow up until after it was built.
Just kidding. Looks like a good mild build/freshen up.
Old 03-11-2010 | 12:57 PM
  #47
Stiner's Avatar
Yeah no sleeves + aftermarket pistons have been equalling cracked sleeve but I believe Area is already on the smallest pulley? and with the ported head it should be easier on everything with less pressure but we'll see
Old 03-11-2010 | 01:31 PM
  #48
hungryhip-ccp's Avatar
what i would be more worried about is how out of round those cyl are after 100k mi. and it looks from the pics no ball hone or even a plateau brush was used to remove oil build up.
not saying it hasent been done before or anything but i would of felt like the stock motor would have been tighter and hold better leakdown and comp #'s then this set up.
it will probably be alright, mine lasted a good 30k on 22+ psi before the sleeve went after the first build.
Now Mr. Bates has taken care of all my worries.
Old 03-11-2010 | 02:37 PM
  #49
it's not less pressure. good god people.
You, my good sir, make some great observations that I have unfortunately overlooked. Props to you!
Old 03-11-2010 | 02:43 PM
  #50
BLAZIN07SS's Avatar
I'm too JDM for you
i always replace rod bearings when it is apart. no matter what. they are too cheap not to replace
