jimbos'ss turbo build
Old 06-27-2008, 02:37 PM
  #551
jimbos'ss's Avatar
Originally Posted by 06blackg85ss
the problem with the tag delete pulley is it's loaded too much, you need to brace the pulley side to the "frame" I'll post pics of mine tonight when I get home from work, eventuall
the pipe side needs to be welded to the bracket with a brace, i noticed mine is bending allready.
Originally Posted by Blown 4-banger
Jim why you movin to Germany? Your not gonna have enough power to fully enjoy the autobahn
puhlees.........
Originally Posted by chevytech007
Glad to see things going well jim!
i'll kindly refer you to this thread:https://www.cobaltss.net/forums/drivetrain-79/leaking-clutch-fluid-118271/
Originally Posted by IonFeright
Jim that video was such a tease! lol Glad to hear it running properly though.
got alot of the little issues out last night and was able to start tuning again! hopefully by the end of this weekend i can have everything squared away, but i also have to move to lancaster this weekend so we'll see.
Old 06-28-2008, 12:03 AM
  #552
jimbos'ss's Avatar
you got those pics, btw i sent you an e-mail of stuff to look at.
Old 07-03-2008, 02:05 AM
  #553
jimbos'ss's Avatar
so i changed the cold side piping a bit and had to retune it, here is a screen shot of a quick 2nd gear pull from 40 mph, bear in mind i have no boost controller as i accidently shipped it to germany with all the rest of my stuff so i'm stuck with a 1.2 bar wastegate spring which equals about 15psi at the intake manifold.
Old 07-03-2008, 04:10 AM
  #554
Blown 4-banger's Avatar
Geesh. 158 degree IAT2 with only 15 lbs???
Old 07-03-2008, 07:16 AM
  #555
06blackg85ss's Avatar
wow that's kinda high, mine is only @115 degrees at 22 psi.
btw how did that file I sent work out.
Old 07-03-2008, 11:25 AM
  #556
lsjwannabe's Avatar
damn i run 154 at the top of third with 28 psi.
Old 07-03-2008, 12:59 PM
  #557
06black's Avatar
that ait is stupid.
i MIGHT cross 120* at the end of 3rd.
Old 07-03-2008, 01:01 PM
  #558
yeah I know, something isn't right there. either he's pushing the turbo too hard, or his IC setup needs some work.
Old 07-03-2008, 01:06 PM
  #559
06black's Avatar
I'm trying to remeber what turbo he has...but i cant rite now.
none the less, i thought it was an SC50, which wouldn't be totally efficient rite there, but at 15psi it shouldent be making **** for heat. the wheel is riding the surge line if anything at that pressure.
Old 07-03-2008, 02:20 PM
  #560
Raven SS's Avatar
he has a turbonetics t3/t4oe
Old 07-03-2008, 02:27 PM
  #561
06black's Avatar
****, thats even closer to being efficient at 15psi...
Old 07-03-2008, 05:05 PM
  #562
jimbos'ss's Avatar
thats because i just moved back up here to the desert and when i was logging it was hot as hell, the intake manifold was heat soaked as well, gotta look at getting a different intake mani gasket because the manifold is aluminum and gets all the heat from the block.
when under boost the iat2's usually drop to about 120. but not when it is this hot out.
it was definately a good starting point, i have since done a lot of maf tuning, i think i finally have the maf dialed in.
no the turbo is barely breaking a sweat, the gate cracks way early at 15 psi. i'll post some logs running it when it's not 110 degrees out and the car isn't completely heatsoaked from tuning for an hour or so.
yah it's not the turbo, coming off the intercooler the heat is a couple degrees more than outside airtemps, but the intake manifold heatsoaks like a ****.
DOES ANYONE MAKE A COMPOSITE INTAKE MANIFOLD GASKET FOR US? i have searched and searched with no luck.
Old 07-03-2008, 11:58 PM
  #563
stryder's Avatar
composite? what kind of material are you looking for? i bet i could get one made of that pholetic materal if need be just not sure how it would seal
Old 07-04-2008, 01:03 AM
  #564
jimbos'ss's Avatar
like one of these but for the lsj ecotec
http://holmart.com.au/online/prod1653.htm
Old 07-04-2008, 01:23 AM
  #565
stryder's Avatar
hmm the piece im thinking about is thinner lol but i think it would work since it resists heat
Old 07-04-2008, 02:27 AM
  #566
jimbos'ss's Avatar
yah i made a gasket today, saw a 40 degree drop in iat2's here's the log, this was from a rolling start to 100mph
Old 07-04-2008, 02:29 AM
  #567
stryder's Avatar
sorry bro still don't know what im looking at lol, help me out to the important points
Old 07-04-2008, 02:33 AM
  #568
jimbos'ss's Avatar
i posted a log on the last page of a 2nd gear pull, look at the iat2 in the first log compared to the second log. the important things for me is the wb afr vs comd afr, kr, inj duty%, map kpa.
Old 07-04-2008, 02:35 AM
  #569
stryder's Avatar
ok cool, thats a nice drop in iats, are you gonna use meth or are you already using it?
so whats your commande afr? 11.8 no knock retard ftw
Old 07-04-2008, 02:37 AM
  #570
jimbos'ss's Avatar
yah it's 11.8, nope my meth kit's on it's way to germany with my damn boost controller.
Old 07-04-2008, 02:38 AM
  #571
stryder's Avatar
hey man you snakes cage really stinks LOL i lost her in the couch (not really lost)
bet you wish you still had those 2 things lol
Old 07-04-2008, 02:40 AM
  #572
jimbos'ss's Avatar
dude did you get her out of the couch?!
yah i definately wish i had the boost controller, i could do without the meth for now.
Old 07-04-2008, 02:42 AM
  #573
stryder's Avatar
yeah shs out, just let her wander around a lil. no worries so i did some logging and im runnng a 10.2 afr i think it might be a lil less than that
Old 07-04-2008, 02:44 AM
  #574
jimbos'ss's Avatar
ok so you need to start tuning, get it at least up to the 11.3 range.
Old 07-04-2008, 02:46 AM
  #575
stryder's Avatar
as soon as i figure out how to do that
Quick Reply: jimbos'ss turbo build
