lnf head on le5 it is possible?
Old 11-04-2008 | 07:58 PM
lafreux's Avatar
I would like to know if is possible to put ss\tc head on a 2.4L ss bloc ??
Old 11-04-2008 | 09:56 PM
Kennyspec's Avatar
No, probably not.
Old 11-04-2008 | 10:00 PM
originaladrian's Avatar
PM maven, he should kno
allot of the heads are interchangeable
Last edited by originaladrian; 11-04-2008 at 10:00 PM. Reason: Automerged Doublepost
Old 11-04-2008 | 10:03 PM
exiged's Avatar
no. lnf doesnt have vvt
Old 11-04-2008 | 10:10 PM
celicacobalt's Avatar
i thought vvt became added on the lnf now.
Old 11-04-2008 | 10:46 PM
Kennyspec's Avatar
i think it has a lot more to do with the DI system of the LNF and the mechanical fuel pump used to control the DI. Will the head physically fit is one thing but what are you going to do about fueling?
Old 11-04-2008 | 10:50 PM
slowswap's Avatar
You fail.
DI is the big question. If it can bolt on, it would be a nice upgrade for those who want to turbo their 2.4.
DI FTW!
Old 11-04-2008 | 11:00 PM
ItalianJoe1's Avatar
It should bolt right up, block casting is the same from what I understand, so the head bolt pattern should match. Not sure if anything else would work though, it would be a custom project for sure.
Old 11-05-2008 | 12:08 PM
IonNinja's Avatar
it would likely be easier and cheaper to just have work done on your existing head
what would be the point of switching from one VVT head to another unless you can pick one up for a hell of a price?
Old 11-05-2008 | 12:53 PM
Omega_5's Avatar
... as some people had mentioned... it should bolt up to the casting... however, there are no injector ports due to the LNF being DI.
You would need to either get the ports machined, or inject in the intake manifold.
Besides that... there is the question as to whether or not the LE5 and LNF use the same VVT control mechanism, and if the ECU will recognize it. I'd assume there should be no issue... but it's best to check.
Old 11-05-2008 | 12:56 PM
Projekt's Avatar
if i am not mistaken, the exhaust cams on the LNF AND LE5 are the same..intake are different? i remember reading this somewhere
Old 11-05-2008 | 01:32 PM
Shermen's Avatar
wont work guys, the lnf has injector ports on the head, it is a direct injected engine, the le5 uses the intake ports to get the gas into the cylinders.
If it does bolt up it would most likely be a tuning nightmare
Old 11-05-2008 | 06:00 PM
IonNinja's Avatar
hmm, which means that probably rules out using the LNF intake manifold as well
Old 11-05-2008 | 06:02 PM
slowswap's Avatar
I stand by what I said. If you want to turbo your 2.4, get the whole top end from an LNF and convert the 2.4 to run with DI.
Old 11-06-2008 | 08:07 AM
Baldturbofreak's Avatar
all parts will physicall interchange. The LNF has very specific DI pistons with a little "sugar scoop" for certain engine modes to bankshot fuel off of.
You would need an entire harness,pcm,footcontrol etc. Bascially you could just buy an LNF complete,new for $3500. and be better off.
Old 11-08-2008 | 11:46 AM
Sw4y1313's Avatar
Would be sick to run a DI 2.4 turbo with custom DI pistons(as said above because of the way it throws fuel). That thing would be sick. You probably could run the LNF ECM. You would just have to make sure you have all the sensors. Would be pretty impressive but a **** load of money. most likely not worth it at all unless you really want a DI 2.4.
Old 11-08-2008 | 12:14 PM
slowswap's Avatar
Your best bet is to take the 2.4 short block and put it in your 2.0 LNF.
Old 11-09-2008 | 08:20 PM
Not unless you can force the PCM into PE all the time. Otherwise it will run like total **** without the sugar scoop.
I will have the first sets of DI pistons in about two weeks. I could have a set cut with the correct compression height for the 95mm stroke of the 2.4. The bore is the same.
weaker crank though.
Old 11-10-2008 | 06:00 PM
IonNinja's Avatar
has there been a change in bore size between the LSJ and LNF? if not, thats incorrect because the LE5 has a longer stroke and larger bore than other Ecotec motors
05-28-2022 03:47 AM
Zharrington_2010LNF
02-08-2016 01:43 PM
01-12-2016 12:01 AM
10-13-2015 09:32 PM
patooyee
10-01-2015 01:07 PM
Quick Reply: lnf head on le5 it is possible?
