SloBalt Rider: LSJ GT3071R Turbo Swap
Old 04-01-2009, 02:36 PM
  #51
slowswap's Avatar
Garrett is just a way better name as far as turbos go. Not saying mitsu is bad, just Garrett is like an industry standard.
Old 04-01-2009, 02:46 PM
  #52
hungryhip-ccp's Avatar
man have i heard that before lol... true though!
just like Borg Warner, mitsubishi... but yet there the ones you find on factory oem vehicles built to last and get forgotten
Old 04-01-2009, 03:24 PM
  #53
slowswap's Avatar
OEM probably runs them because they're cheaper?
Old 04-01-2009, 03:33 PM
  #54
probably lol
Old 04-01-2009, 03:54 PM
  #55
06black's Avatar
borg and holset are #1 OE, HTI and Honywell(garrett) are huge tho too
borg's made a KILLING on the K0X line up, builtproof units that always deliver.
Old 04-01-2009, 05:02 PM
  #56
SloBaLt RiDeR's Avatar
Originally Posted by Mike09SS
damn gonna be some quick cobalts in western NY this summer. Cant wait to see this
yea iam dying to drive my girl again.... without traction this time lol
those bearings are gonna be to tight and your gonna need to get the crank sized to them. polished at least. thats why i kept the stockers...
yes you should def get the balance shaft delete by "level zero motorsports"
if the motor is out do it!
that turbo will be fine. little laggy for the goal/application but it will do.
no-one like mitsu's or what........
12 month/unlimited mileage warranty
Outstanding response: full boost by 3500 RPM, matches ball-bearing turbo performance at an affordable price
Killer top-end performance: pulls hard all the way to redline
World-class efficiency from ultramodern design wheels and housings, not dated 1960’s technology like T3-T4
Specifically designed to fit Cobalt when combined with other Hahn components (shown below)
Super-efficient, dependable internal wastegate
15 PSI boost standard, can be combined with a boost controller for higher boost levels
Does not require coolant lines
Easily rebuildable, super-durable journal bearing design, does not require factory servicing like expensive ball-bearing units
Effective and efficient to over 30 PSI boost
H TU-3100 $899.99
http://www.turbosystem.com/ProjectVe...Components.htm
hey hip, can you tell me more about these balance shaft deletes?
are they hard to put in? and is it "easy" to see how they go in place?
the rod bearings are stock by the way, i just replaced them, i forgot to mention that.
Last edited by SloBaLt RiDeR; 04-01-2009 at 05:02 PM. Reason: Automerged Doublepost
Old 04-01-2009, 05:50 PM
  #57
Mike09SS's Avatar
[QUOTE=SloBaLt RiDeR;3683646]yea iam dying to drive my girl again.... without traction this time lol
lol dont worry....after 50 or 60 you will have traction.....and a huge smile on your face.
Old 04-01-2009, 06:25 PM
  #58
SS/SCking's Avatar
Old 04-01-2009, 06:26 PM
  #59
lol idk from what iam hearing idk if iam ever going to have traction
Old 04-01-2009, 06:28 PM
  #60
SS/SCking's Avatar
lol me ether.....
  #61
slowswap's Avatar
http://www.youtube.com/watch?v=Jrr-VPmWO8Y
It'll be like this.
Old 04-01-2009, 06:32 PM
  #62
lolol my goal is 1188 whp so yea that will be me lol. fail
Old 04-01-2009, 06:36 PM
  #63
slowswap's Avatar
I just meant the spinning through 2nd and 3rd.
  #64
SS/SCking's Avatar
lol that should be fun
Old 04-01-2009, 06:39 PM
  #65
yea 2nd and 3rd... theee important gears i need lol i dont think iv ever raced anyone in 4th gear
  #66
1BADSS/SC's Avatar
Build Fasterrrrrrr!!!!!!!!
Old 04-01-2009, 06:46 PM
  #67
SS/SCking's Avatar
until now.....
Old 04-01-2009, 06:51 PM
  #68
well stated.
hey dan did you get these balance shaft delete kit? from level zero motorsports?
Last edited by SloBaLt RiDeR; 04-01-2009 at 06:51 PM. Reason: Automerged Doublepost
Old 04-01-2009, 06:58 PM
  #69
TheSauce's Avatar
what ever stock fuel pressure is. iam assuming its 50psi correct. i plan on running at 20 21 pounds of boost, for highway runs and track. and 15 or so for daily driving. how do you calculate the duty cycle? so ill be fine with the 60 lbs injectors? or should i go with the 79lbs, walbaro 255lph for room to play with? i also heard the 79lbs are a bitch to tune?
Well the duty cycle is going to be the "on time" of the Injector per 2 revolutions of the crankshaft. I used 80% in my math because that's the normal on time to be safe. I found a website that can show you the duty cycle at diff rpms. here it is
http://www.stealth316.com/2-calc-idc.htm
According to the graph in the middle of this page, you would be at 70% at 7000 rpms, so would still have a bit of cushion. I think the 79# injectors would be overkill, would have to cut the on time way down, not sure how hard it would be to tune them though. I will try to find the specs on the stock fuel pump to see if you would exceed the specs or not. I also looked at the Turbo Compressor Map and at 20psi you would be in the target area... might have a little lag at 3250, but not much.
Old 04-01-2009, 07:04 PM
  #70
SS/SCking's Avatar
well stated.
No this is the first time ive herd of it...
Old 04-01-2009, 07:06 PM
  #71
^^awesome great. well from the info i'll run the 60's i have and RSFS. to be safe
great info u give
check them out, hungryhip-ccp said they are a real good idea, since we running "big" power
Last edited by SloBaLt RiDeR; 04-01-2009 at 07:34 PM. Reason: Automerged Doublepost
Old 04-01-2009, 07:19 PM
  #72
SS/SCking's Avatar
Ill check them out
Old 04-01-2009, 07:41 PM
  #73
levelzeromotorsports.com
Old 04-01-2009, 07:45 PM
  #74
SS/SCking's Avatar
delete kit..
Old 04-02-2009, 10:46 AM
  #75
u gonna buy them, cuase iam
Quick Reply: SloBalt Rider: LSJ GT3071R Turbo Swap
