Spike's build thread
Old 11-23-2009 | 01:27 PM
  #226
spike's Avatar
turbo manifold and exhaust side of turbo going to jet hot next week
Old 11-23-2009 | 01:31 PM
  #227
hungryhip-ccp's Avatar
looking good!
Old 11-23-2009 | 01:38 PM
  #228
spike's Avatar
Originally Posted by jimbos'ss
makes a lot of sense actually. better to take your time and hit every detail than miss something small that turns into a disaster later
hey jimbo wat hardware did you us to mount your turbo mani?
Old 11-23-2009 | 01:58 PM
  #229
jimbos'ss's Avatar
m10 studs and copper nuts
http://www.atpturbo.com/mm5/merchant...egory_Code=FST
i reccomend tac welding the studs to the manifold, or else they'll fall out time after time.
Old 11-23-2009 | 02:10 PM
  #230
Cefaln452's Avatar
where and whats the model number for the arp main studs?
  #231
spike's Avatar
cool thanx
Old 11-23-2009 | 02:21 PM
  #232
jimbos'ss's Avatar
no problem
Old 11-23-2009 | 02:33 PM
  #233
spike's Avatar
idk contact stewart race engines in Indy they are the one that handled all of that....stocks hold fine though
Old 11-23-2009 | 02:37 PM
  #234
Cefaln452's Avatar
what about your rod cap bolts?
Old 11-23-2009 | 03:19 PM
  #235
spike's Avatar
They are ARP came with the Pauter rods
Old 12-02-2009 | 01:52 AM
  #236
spike's Avatar
ordered some stuff today
-O.E. radiator
-IAT2 sensor
-MAP sensor
-O.E. overflow tank
-exhaust mainfold studs and nuts
the next two weeks plans
-ceramic coating friday
-Earls for lines and goods friday
-front and rear brake pads
-rear rotors
goal is to be ready for charge pipe fabbing in two weeks if the ceramic stuff is done by then
Old 12-14-2009 | 02:29 PM
  #237
spike's Avatar
got my lines and stuff from Earl's for $69
got the mani and exhaust side ceramic coated by Pro-kote indy
Old 12-14-2009 | 02:31 PM
  #238
06blackg85ss's Avatar
looking good man
Old 12-23-2009 | 02:25 AM
  #239
spike's Avatar
Im getting really sick of this thing right now. Builds suck when you get way in past your knowledge level if anyone wondered. I am really wishing that i would have done some things alittle different now. I went through and read some of my post about my plans and now want to kick my own ass lol. This has been a long problem filled build and for the most part was a huge waste of cash.
thanx to 06black, Area47, 06blackg85ss, jimboss, and others for the good advice just wish i would have listen more
live and learn i guess
Old 12-23-2009 | 02:57 AM
  #240
*S!CC_R@c!NG_TURTL3*'s Avatar
i feel you man itll be well worth it in the end trust me
Old 02-03-2010 | 12:12 AM
  #241
spike's Avatar
well the manifold and turbo is on, but idk if its staying on or if im buying new stuff due to clearance issues.
the turbo is bout a fingers width from the steering rack with the nuts tight. I can get another half inch if i take the steering rack spacers out, but idk if i need to with my mounts. The side of the mani is about the tickness of a ruler from the heater hose hard pipe, but that can be fixed with alittle heat. Still dont know about if the turbo is high enough to drain oil well. My biggest problem is a down pipe though. There is only about 3.5" of room comfortably(from flange to mount) according to my card stock paper down pipe. And thats for a 90 degree bend.....so.....
well i need the flat head bolt, heat and bend the coolant pipe slightly, remove the steering rack spacers, buy the elbow listed above+ a 45degree bend. then all will be fine again maybe. Still need to find out how high above the drain hole the turbo should be????
here my mock up down pipe
Old 02-14-2010 | 01:09 AM
  #242
spike's Avatar
winter wheels back
Old 02-14-2010 | 04:10 AM
  #243
jimbos'ss's Avatar
how low is your car? might be worth it to remove the rack spacers, another thought is if have a good welder or can weld and cut yourself, just cut a half inch off the collector and put on a new flange. shitty thing is it will **** up your coatings though. BTW did you do the AC delete?
Old 02-15-2010 | 12:05 AM
  #244
Stiner's Avatar
Mine is close as well not sure if it will be an issue though? oh and dont mind the kink in the drain line I've since shortened it up should drain beauty.
Old 02-15-2010 | 01:14 PM
  #245
spike's Avatar
Yeh im just going to take out the rack spacers.Should gime about as much room as Stiner^^^. yeh i did the ac delete the Qwiks way....
Stiner do drive your car now? how well does the oil drain from the turbo with the new hose?
Old 02-15-2010 | 01:20 PM
  #246
jimbos'ss's Avatar
holy **** thats cool, been thinking about doing an ac delete myself, never use it.
Old 02-15-2010 | 01:47 PM
  #247
Stiner's Avatar
Haven't drove it yet should know fairly soon. going to fire it up to make sure everythings working properly.
Old 02-15-2010 | 02:04 PM
  #248
Edubs's Avatar
I'm seriously contemplating pulling mine out as well. It would be freaking super easy for me right now cause the motor is out...
It's like getting a tattoo, I just want to make sure I'm not going to regret it. It's possible to reverse, just not easy and usually never the same.
Old 02-15-2010 | 02:14 PM
  #249
jimbos'ss's Avatar
my biggest concern would be leaks in the system if i tried to reverse it.
Old 02-15-2010 | 02:15 PM
  #250
pick up a junkyard comp?
Quick Reply: Spike's build thread
