What methanol nozzle size?
#151
5gph may not be enough but its certain better to start off to small than go to big. We are talking about peoples motors here. So i always try to give safe knowledgeable advice. If your too small you will still get some of the cooling benefits of the water/meth. Without risk of engine damage.
If you go to big your going to have to remove fuel to make it run right. This is not always a safe tuning practice.
It takes trial and error to come up with the proper nozzle size.
As for a cool tank, these should be out very shortly.
http://www.alcohol-injection.com/2-5...-tank-346.html
Features a real sump,
internal baffle for fluid control under braking
Same material and construction as fuel cells
Proper cooling for the pump.
Smc252 (12-19-2021)
Smc252 (12-19-2021)
